Wrecked, Help? - Honda Accord Forum : V6 Performance Accord Forums
Old January 17th, 2013, 05:59 PM   #1
demeyz's Avatar
Wrecked, Help?
So I was involved in a collision yesterday and the car is still running, but I was noticing some strange symptoms as a result. The guy hit me on the front passenger side, ended up with a deformed hood and fender, the headlight is destroyed and the bumper needs to be replaced. Haven't noticed any fluid leaks nor has it threw any codes, but the drive belt is now squealing noticeably. Not loud, but it wasn't doing it before. Car also seems to idle higher. Engine temp is normal.
Luckily insurance is covering it, but is there any possible underlying issues I should be aware of? This is on a 4-cyl model.
demeyz is offline   Reply With Quote Quick reply to this message
Old January 17th, 2013, 06:13 PM   #2
Randomhero's Avatar
Get it professionally checked out on the insurances dime.
Sounds like it might have bent something important.
Current:
08' BMW E90 335i 6MT ~420whp
Old January 17th, 2013, 06:15 PM   #3
nguoikhogiai200's Avatar
Any picture? the noise may due to the belt rub against bent parts. And always have it checked out at professional & trusted place.
nguoikhogiai200 is offline   Reply With Quote Quick reply to this message
Old January 17th, 2013, 07:32 PM   #4
3.0UALLKNOW's Avatar
Make sure youre coolant lines arent pinched shut
3.0UALLKNOW is offline   Reply With Quote Quick reply to this message
Old January 17th, 2013, 07:53 PM   #5
Old Member
Du3ce's Avatar
and your frame isnt bent
Old January 31st, 2013, 11:50 PM   #6
My guess is something in there was bent. Since collisions can cause multiple problems, the squealing can be multifactorial. Its pretty much a look and see whats broken type deal now. Like everybody else suggested, just bring it in somewhere reliable
Joshcolorado is offline   Reply With Quote Quick reply to this message
