timing belt noise when cold? - Honda Accord Forum : V6 Performance Accord Forums
Old February 3rd, 2013, 11:55 AM   #1
I live in Minnesota and it has been cold lately. My timing belt is making a noise when I first start my car, but after it warm up the noise goes away. I'm pretty sure it's the timing belt because the first time I heard the noise I lube my belt with a little of engine oil and it went away.
Should I be worry it might turn into a bigger problem?
fareast is offline   Reply With Quote Quick reply to this message
Old February 3rd, 2013, 12:08 PM   #2
timing belt or serpentine belt? Might want to replace the serpentine belt then.
Old February 3rd, 2013, 12:16 PM   #3
Honda enthusiast
michaellowrider's Avatar
Yes. Don't put engine oil on belts, it's bad for the rubber, eats it up. You should change the belt. Is it the timing belt or the accessory belt, timing belt is under a cover on opposite side I think. I have a noise when cold also but haven't diagnosed it yet. Its usually a tensioner pulley for the accessory belt going bad.
Old February 3rd, 2013, 05:17 PM   #4
Ohh oops I thought it was the timing belt but I guess it's the accessory belt. This belt right? 2005 Honda Accord i4 Noise Take 2 - YouTube
Old February 3rd, 2013, 05:22 PM   #5
i4 doesn't have timing belt either. it has a timing chain. Definitively serpentine belt.
Old February 3rd, 2013, 05:26 PM   #6
Sorry, I couldn't find a v6 version.
Old February 3rd, 2013, 06:06 PM   #7
The name is Z
CrackerTeg's Avatar
Yes. That would be the belt making the noise. Costs about $30 and takes all of 20 minutes to replace.
Old March 3rd, 2013, 02:59 PM   #8
It sounds like the accessory belt tensioner to me.
spydercatt is offline   Reply With Quote Quick reply to this message
Old March 4th, 2013, 03:00 PM   #9
1979rs/z28's Avatar
sounds like tensioner. without the belt on check the play on the idler/tensioner
1979rs/z28 is offline   Reply With Quote Quick reply to this message
Old March 29th, 2013, 01:49 AM   #10
does anyone have manual to replace the belts and tensioner or pulley? Mine is also making the same sound
sub7viet is offline   Reply With Quote Quick reply to this message
Old March 31st, 2013, 08:34 PM   #11
if it squeaks, it's the serpentine belt. if it's like metal to metal clunk or chatter, prolly the timing chain.
cha_cheng is offline   Reply With Quote Quick reply to this message
