Drivers window shakey when rolling down - Honda Accord Forum : V6 Performance Accord Forums
Like Tree2Likes
  • 1 Post By toinkee69
  • 1 Post By Ryguy1992
Old February 6th, 2013, 08:35 AM   #1
Ryguy1992's Avatar
Anyone have this issue? My window will roll up fine but when going down it'll shake while going down.
Ryguy1992 is offline   Reply With Quote Quick reply to this message
Old February 6th, 2013, 09:16 AM   #2
JDM UC1
toinkee69's Avatar
your motor will prolly give way soon.
Old February 6th, 2013, 09:25 AM   #3
The name is Z
CrackerTeg's Avatar
I'd try greasing the window tracks a bit and see if that handles it. I forget what the stuff is called that Honda uses.
Old February 6th, 2013, 09:36 AM   #4
JDM UC1
toinkee69's Avatar
http://www.handa-accessories.com/shin.jpg
CrackerTeg likes this.
Old February 6th, 2013, 10:06 AM   #5
The name is Z
CrackerTeg's Avatar
Yes! Shin-etsu grease!
Old February 7th, 2013, 07:25 PM   #6
Sometimes mine makes an extremely high pitched squeak when i roll it down. Only happens about twice a month after the car has been sitting in the sun for awhile. If i push out on the window when i roll it down it doesn't do it. Any ideas?
cmv94 is offline   Reply With Quote Quick reply to this message
Old February 12th, 2013, 01:52 PM   #7
jpawela's Avatar
When it's cold out, mine rolls down fine about half way and then clunks and moves slightly and then continues on all the way down. When it's warm (like it is most of the time here in New Mexico) it works fine so I haven't bothered to open up the door yet to see whatsup.
jpawela is offline   Reply With Quote Quick reply to this message
Old February 15th, 2013, 03:08 PM   #8
Some things to try:
1)Silicone spray the window tracks.
2)Some have recommended "Rain-x"ing the window.
3) A friend of mine replaced his regulator twice.I had a thought that if you partly disassemble the regulator tranny(under mtr) & greased it(& cables) up.That should solve it w/o spending $166+ on a rgltr.What happens is as it looses lubricity it becomes harder for the mtr to turn till the mtr burns out.
I had a old Civic that was cranking up so bad.I was sure i'd needed a new window regulator & all.NOT a easy job to do(trip to junkyard,$$ & the tear out(2x's).So what I did was to remove the door panel Greased anything that moved.Got a big plastic syringe & injected synthetic grease in the areas I couldn't get in.....The window worked like new.
Silvershadow is offline   Reply With Quote Quick reply to this message
Old February 15th, 2013, 07:26 PM   #9
Czechopino
vasekvi's Avatar
Use white lithium grease in the tracks and make sure the rubber tracks havent come out of place in their frames. I had to fix this 5 years ago no problems since. Passenger side front window was slow to roll down when I first bought my car
My SSM Sedan Mod Thread
Old March 12th, 2013, 10:38 PM   #10
Ryguy1992's Avatar
UPDATE: used silicone spray a few times moving the window up and down between sprays. Haven't had an issue since than
3.0UALLKNOW likes this.
