valve cover replacement question? - Honda Accord Forum : V6 Performance Accord Forums
Old February 10th, 2013, 08:30 AM   #1
Hello v6p I have a 03 accord sedan v6. I have a leak on my valve cover so I'm planing to replace it. My question is what other parts or gaskets should I take in consideration on changing out since I'm taking apart the manifold and valve covers. So far what I have on mind to change out is the,, valve cover gasket,top manifold cover gasket,bottom manifold gasket,throttle body gasket, that's bout it. Please if I'm missing out a part or gasket give me a heads up. Thanks for your help and time.
03accord_Ex is offline   Reply With Quote Quick reply to this message
Old March 3rd, 2013, 03:04 PM   #2
I would do the exact same thing as you have mentioned. If you are thinking about removing the throttle body to get the intake manifold off then look into getting those gaskets as well. But you don't need to really, you can take the intake manifold off without removing the TB, just make sure you disconnect all the electrical connectors and hoses.
spydercatt is offline   Reply With Quote Quick reply to this message
