What is this noise? (Vid) - Honda Accord Forum : V6 Performance Accord Forums
Like Tree7Likes
  • 1 Post By 1fastJ30A1
  • 1 Post By Randomhero
  • 1 Post By BLCKFLSH
  • 1 Post By Milan
  • 2 Post By Sonnick
  • 1 Post By 05accord6spd
Old February 23rd, 2013, 12:44 PM   #1
Sonnick's Avatar
IMG_0703_zps7990d1cf.mp4 Video by Sonnick | Photobucket
Instagram = j30_allmotor
Old February 23rd, 2013, 01:14 PM   #2
-Maninder
i've heard that sound from power steering before so maybe start there
Sonnick likes this.
Old February 23rd, 2013, 02:01 PM   #3
Sonnick's Avatar
^ Thanks. I did get the letter in the mail from Honda noting that my car could potentially be one affected by the power steering hose. It doesn't sound like a hose though, but in the morning when I turn, it does make a whining noise. You're probably right. I'm at ~108k by the way.
My valves do tick rather loud as well, probably in need of a valve adjustment.
Old February 23rd, 2013, 02:14 PM   #4
Randomhero's Avatar
Aliens
Sonnick likes this.
Current:
08' BMW E90 335i 6MT ~420whp
Old February 23rd, 2013, 09:48 PM   #5
BLCKFLSH's Avatar
The recalled hose (pressure hose) is probably not the hose causing the noise (feed hose). The noise is probably coming from the faulty o-ring on the pump feed hose that goes into the bottom of the pump, from the reservior.
Sonnick likes this.
BLCKFLSH is offline   Reply With Quote Quick reply to this message
Old February 23rd, 2013, 10:04 PM   #6
Picture Perfect
Milan's Avatar
Yes, that was my thinking too. If you haven't replaced it with the new o-ring that could be your problem. I replaced it on mine a year (or two) back. Took maybe a day to go away even after the new o-ring but haven't had any issues since.
Sonnick likes this.
Old February 24th, 2013, 06:21 AM   #7
Honda enthusiast
michaellowrider's Avatar
That whine is air in the system leaking past the tsb'd o-ring. It's like $0.39 at the stealership, what a rip-off! Lol
Old February 24th, 2013, 10:02 AM   #8
Mine whines as well, but only when cold. Anything above 20 degrees it doesn't make a sound.
200366HFP is offline   Reply With Quote Quick reply to this message
Old February 24th, 2013, 10:31 AM   #9
chuloav6's Avatar
Happened to my car last year, O ring fixed it.
chuloav6 is offline   Reply With Quote Quick reply to this message
Old February 24th, 2013, 01:48 PM   #10
Did this today but had to put my old o ring back in since the new one seemed to be too big. Is that normal?
blackeoutse is offline   Reply With Quote Quick reply to this message
Old February 24th, 2013, 02:10 PM   #11
Honda enthusiast
^The updated o-ring is orange, same exact size/dimensions, they gave you the wrong part. Inlet Joint O-ring (orange): P/N 91345-RDA-A01, H/C 8811010
Old February 24th, 2013, 02:14 PM   #12
Wow thought something was up... Idiots over at Honda city. Thx man appreciate it.
Old February 24th, 2013, 07:22 PM   #13
Sonnick's Avatar
^ Honda City on Long Island? Lol they're the worst, coined 'Honda sh1tty' for a reason.
Thanks for the responses guys. I will get that replaced ASAP.
Milan and blackeoutse like this.
Old February 24th, 2013, 07:29 PM   #14
I <3 My J30A4
qnzthg89's Avatar
Just like you would with swapping your old slave cylinder with the new one that does not have the check valve right? i keed i keed
Old February 24th, 2013, 08:11 PM   #15
Slammed & Stunning
MatthewYu's Avatar
Go to the dealership..
It's free. And they not only replace the Oring but the whole entire pump tubing. FREE
Old February 25th, 2013, 04:19 AM   #16
Picture Perfect
Milan's Avatar
That's if they have the new parts in which case many do not...yet. I'd replace the o-ring rather than wait for the new parts to come in.
Old February 28th, 2013, 08:02 PM   #17
Czechopino
vasekvi's Avatar
How does it sound when you turn the steering wheel? Here is a DIY for the O ring.
http://www.v6performance.net/forums/...p-tsb-diy.html
My SSM Sedan Mod Thread
Old February 28th, 2013, 09:01 PM   #18
Picture Perfect
Milan's Avatar
Son of a b!tch...my car was running fine all this time, then this thread pops up and this morning it starts moaning again. Can't wait for the new power steering hoses to come in, hope that fixes it for good.
Old March 1st, 2013, 09:42 PM   #19
BLCKFLSH's Avatar
I repeat, the recalled hoses are not the same hoses that have the bad o-ring. One is going to the pump, and the other is going from the pump.
Old March 3rd, 2013, 02:54 PM   #20
The recall is for a bad O-ring put on at the factory. A simple way to check and see if it has been done, the old O-ring is black, the new O-ring is red. The part at the dealership is less than a dollar and if air is getting into the system you will see what looks like the PS fluid boiling once the vehicle has been shut off. In very bad cases the air in the system has to go somewhere and the weakest link is the PS reservoir so it will begin pushing the fluid out of the top of the res. It will be something you will notice on the ground. Also it could be a bad bearing in the power steering (PS) pump. If you are losing fluid make sure you check it often, you do not want to use it with no fluid, that is serious money to fix the whole PS system. Also on the passengers side is the timing belt it has 2 bearings and a water pump. Those could be going out as well.
One way to pin point the noise, take a long screw driver or any long piece of metal and with the engine running place the tip of the screw driver on the suspected part (don't get caught in the belt or the fan blades), then place the other end against your ear and see if you can hear the noise only a lot louder, then keep moving it to different components to pin point the noise.
spydercatt is offline   Reply With Quote Quick reply to this message
Old March 3rd, 2013, 05:38 PM   #21
Sonnick's Avatar
Thanks for the replies. When I turn, it only gets louder, like it 'revs' almost. It's only when it's really cold though, otherwise it just whirs at startup, then once it warms up it stops.
I just had my tbelt, thermostat, and water pump replaced. Didn't really notice if it got worse after the install.
My CEL keeps coming on every 2 days or too, it's really pissing me off. Gotta get the code checked.
Old March 4th, 2013, 11:01 AM   #22
What are the specifics on your car? Year, make, model, mileage, and who did the timing belt?
Old March 4th, 2013, 05:08 PM   #23
Picture Perfect
Milan's Avatar
Well the problem is that I already replaced the bum o-ring with the new one. The squeaky noise was with me for about 4-5 days and today it went away. The power steering growling went away too. It was sunny after a long time so I'm guessing the belt finally dried but I can't say why that would also affect the power steering pump and air getting in the system.
Old March 6th, 2013, 11:35 AM   #24
Sonnick's Avatar
2006 Accord V6-6 with 108K and rising, just under 2K per month or so. A friend of a friend did it, but he is a mechanic.
Old March 7th, 2013, 11:58 AM   #25
05accord6spd's Avatar
my car did the power steering noise problem like at 140k miles, we replaced the power steering pump like 2 times before another shop found it was the high pressure hose, i would rec just going and getting the warranty done and see what happens. the noise would stop for a while then come back untill the leaking high pressure hose was fixxed after that it all went away. other wise it just sounds like a bad pulley in your accessory belt
Sonnick likes this.
Old March 7th, 2013, 01:31 PM   #26
Sonnick's Avatar
Yea it whines when the wheel is turned as well. It's embarrassing lol.
Also, I'm thinking the ticking could be from my injectors...I believe the sound is coming more from underneath the intake manifold than the valve cover(s).
Old March 7th, 2013, 07:54 PM   #27
If it is whining when its turned it's definitely the O-ring. I had it replaced and it was the best $1.00 I spent!
Accord6Speed909 is offline   Reply With Quote Quick reply to this message
