CEL - Under Full Acceleration - Honda Accord Forum : V6 Performance Accord Forums
Old April 7th, 2013, 10:08 AM   #1
sirchadwick's Avatar
Check engine light flashes when under full acceleration.
Ideas or thoughts?
2004 Accord 5AT
64,000
Borla Cat Back
Third Cat Removed
UA Pulley
K&N Air Intake
J-Pipe
sirchadwick is offline   Reply With Quote Quick reply to this message
Old April 7th, 2013, 11:21 AM   #2
Ryguy1992's Avatar
Check your spark plugs. Make sure there in tight and the condition of the tip is good
Ryguy1992 is offline   Reply With Quote Quick reply to this message
Old April 8th, 2013, 06:02 PM   #3
have you got an O2 defouler/simulator? post-cat O2 sensor may be reading high voltage.
cha_cheng is offline   Reply With Quote Quick reply to this message
Old April 9th, 2013, 12:44 AM   #4
03 AV6 Coupe
hondav6's Avatar
probably a misfire. maybe time to change your spark plugs. These engines run rich from what I understand, especially with mods.
2003 Honda Accord EX V6 Coupe
Injen CAI
Magnaflow CBE
UR Pulley
Richie's V3 J-Pipe
J35 Magnesium IM
MDX IM Spacer
P2R Thermal Gaskets
TB Coolant Bypass
Innovative 60A Mounts
Koni Yellows/Eibach Pro Kit
TL-S Rear Sway Bar
Neuspeed Strut Bar
Old April 9th, 2013, 09:12 AM   #5
Randomhero's Avatar
Get your ECU reflashed and updated by honda. Worked for me.
Current:
08' BMW E90 335i 6MT ~420whp
Old April 9th, 2013, 02:04 PM   #6
Picture Perfect
Milan's Avatar
I also had a flashing CEL a few weeks ago when doing a full-throttle merge onto a freeway (50-85MPH). Light quit flashing and went away. Came back the same day a few hours later, stayed for about three days, went away and hasn't returned since.
My plugs are OEM Honda about 15k miles on them. PCD with defoulers. Thinking it may be my O2 sensors, they are original and car is pushing 170k miles.
Old June 15th, 2013, 10:28 AM   #7
I have some questions about changing he plugs.
Probably mentioned here somewhere, but what brand and type are you guys using. Called the dealer and they want $321 to do the work. I told them to get bent.
Old June 15th, 2013, 09:25 PM   #8
Honda enthusiast
michaellowrider's Avatar
I've got platinum denso cuz I'm a cheap azz lol, works fine. Iridium ngk is oem i think, which is best. Maybe when I'm rich I'll feel like spending $10+ per plug. Maybe
Old June 16th, 2013, 09:57 PM   #9
Randomhero's Avatar
Your gonna end up eating the cost anyways cause your platinum plugs will not last 105k. Probably, 60k.
Current:
