Clutch issue - Honda Accord Forum : V6 Performance Accord Forums
Old April 15th, 2013, 10:28 PM   #1
Clutch issue
Well I've searched and haven't been able to find anyone else with the same symptoms so going to ask for some opinions. Or maybe one of you has had the same thing and can give me answers.
In my '06 Sedan, the clutch will engage immediately as pedal comes up off the floor only when I have held it in at a stoplight for some period of time (like 30 seconds+). A quick pump or two and it is fine again. If I don't hold it in for long, all seems normal. Haven't seen any fluid leaks. This has been going on for quite some time (maybe 50,000 miles) and I've just lived with it since it's not really too difficult to drive this way.
Now I'm going to put a new clutch in since I'm putting a J32A3 in soon and the original clutch has 223,000 miles. Seems like a good time to change the clutch even though it isn't slipping. But I'm wondering if I should go ahead and change the slave and/or Master to correct this problem. Not a big deal to just change them, but I don't want to throw parts at it without having a better idea of what the problem is. Certainly seems like hydraulic issue to me, but I suppose it could be the pressure plate.
Any suggestions or experience with this is appreciated.
Thanks,
Todd
06Accord6spd is offline   Reply With Quote Quick reply to this message
Old April 15th, 2013, 10:34 PM   #2
either you have bubbles in the line or the pressure plate is death. What does the clutch fluid look like?
Old April 15th, 2013, 10:49 PM   #3
Good question... I've really kind of ignored it but will check that out tomorrow.
Do you think the the pp could cause this but still not allow the clutch to slip?
Old April 15th, 2013, 11:23 PM   #4
Slammed & Stunning
MatthewYu's Avatar
YES^..
How do you even have 220k+ miles on your stock clutch my God..
Your engine must have never been pushed 3k rpms hahaha
Old April 15th, 2013, 11:32 PM   #5
Originally Posted by MatthewYu View Post
YES^..
On the contrary... My car has seen regular track (road course) duty every season.
And my bent valves are evidence of high rpm. DOH
Hence - the J32A3 swap since I just can't see putting another timing belt on an engine with bent valves. Plus it's cheaper than fixing the J30. And fyi, the valves were bent with about 80K miles on the clock. Rough idle and perpetual CEL, but it still gets 28 - 31+ mpg on the highway.
Old April 16th, 2013, 12:23 AM   #6
Slammed & Stunning
MatthewYu's Avatar
I bent my valves and put in a new J30A5. In fact I just got her back today..
I'm in love. Did the water pump and timing belt.
Labor for $800 which included water pump and timing belt, labor for swap, new NGK plugs, coolant, rear seal, and seafoam.
Old April 16th, 2013, 07:16 AM   #7
Thanks,
Todd
Sounds like what happens with your brake pedal over time if you don't flush out the old fluid and rebleed with new. Doesn't necessarily mean there is anything wrong with your clutch. But with that many miles, and a newer motor swap on the way, I'd replace it with the swap.
200366HFP is offline   Reply With Quote Quick reply to this message
Old May 13th, 2013, 08:44 AM   #8
Yeah, I also want to know that...
Adwerd is offline   Reply With Quote Quick reply to this message
