Clutch chatter developing - Honda Accord Forum : V6 Performance Accord Forums
Old April 27th, 2013, 01:04 PM   #1
Have had the car now almost 3 months. Did the slave cylinder valve delete about a couple weeks ago. Since then, it felt to me that after a shift, the instant the clutch and driveline connect again, the engagement is harsher than it was before and sometimes I hear a thud. I know this might be normal since the valve acts like a damper. This past week I've noticed that the car now has a light chatter when taking off from a stop. I'm wondering if any of the following could have contributed:
Removal of the valve and harder clutch engagement. Motor mounts do not look broken
Due to hotter temperatures recently, use of the A/C at full blast and therefore slipping the clutch a little more at take offs to prevent the car from bogging
The car has had 2 previous owners, and don't know what their driving style was
I'm curious because when I had the 03 6-6, I didn't remove the slave cylinder valve, and I drove the car for probably 2 months without clutch issues. Any insight appreciated. The chatter is light, but noticeable and I know for sure it wasn't there before
2008 Acura TL Type-S NBP
Past:
2007 Black coupe 6-5AT
2006 Silver coupe 6-6MT
2006 Black coupe 6-5AT
2005 Graphite coupe 6-5AT
2003 Black coupe 6-6MT
mc1114 is offline   Reply With Quote Quick reply to this message
Old April 27th, 2013, 01:07 PM   #2
how many miles. Maybe time for a new clutch
Old April 27th, 2013, 01:16 PM   #3
82k. It grabs tight and at the normal pedal height
Old April 27th, 2013, 01:24 PM   #4
bleed the system again?
Old April 27th, 2013, 05:30 PM   #5
Just drive it normally for a while and don't slip it or drive aggressively. It's easy to get uneven friction material transferred to the flywheel or pressure plate if you ever slip the clutch on an aggressive take-off. If you drive conservative for a while it will wear down and be smooth again.
Old April 29th, 2013, 12:16 AM   #6
Thanks guys. I was worried at first but not thinking about it much anymore. If it persists, I'll just fix it myself since I work at a shop
Past:
Old May 5th, 2013, 12:25 AM   #7
I wanted add a question to this if I could -
My clutch only has about 20,000 miles on it - a while ago I was tired and my foot slipped off the clutch kiling the motor pretty harshly. It's been rough and chattery ever since (about 10,000 miles) but will not slip even when driving super agressive. I'm guessing a finger on the pressure plate broke? Any ideas? (my original clutch was changed at 120,000 miles and it was because the trans was leaking on it and burnt it up, so I know I didn't burn it up too fast)
and lastly - does everyone else find the engagement on the 6MT clutch high? It grabs at about half way, always drove me nuts
metalrocker is offline   Reply With Quote Quick reply to this message
