Taillights and Corner lights WON'T turn on - Honda Accord Forum : V6 Performance Accord Forums
Like Tree4Likes
  • 1 Post By ertpecs
  • 1 Post By CrackerTeg
Old May 27th, 2013, 09:34 PM   #1
Striking-A-Chord
StrikingAccord's Avatar
Question Taillights and Corner lights WON'T turn on
After my retrofit headlights were installed I noticed that my taillights don't come on when my headlights are on.
My corner lights also won't turn on.
My turn signals and brake lights work fine.
I checked the fuses and they were ok. What could this be?
Thanks.
2004 Accord EX V6 Coupe
Let's Go Mets!
StrikingAccord is offline   Reply With Quote Quick reply to this message
Old May 27th, 2013, 09:42 PM   #2
dave
ertpecs's Avatar
Did you mess with any of the grounds? I'd check them.
StrikingAccord likes this.
ertpecs is offline   Reply With Quote Quick reply to this message
Old May 27th, 2013, 10:03 PM   #3
Striking-A-Chord
thanks for your reply
I will check later on today
Let's Go Mets!
Old May 28th, 2013, 08:31 AM   #4
The name is Z
CrackerTeg's Avatar
Your problem screams of the parking light fuse going out.
Old May 28th, 2013, 10:13 AM   #5
Striking-A-Chord
Thanks for the reply man.
Are the rear parking lights related to the front corner lights? How would changing the headlights affect them?
My brake lights and signal lights (front & rear) work fine.
I will double check the fuses.
Let's Go Mets!
Old May 28th, 2013, 12:34 PM   #6
The name is Z
CrackerTeg's Avatar
Yes they are. If only your headlights come on when you turn on your lights, you blew a fuse. I'll bet nothing turns on if you only go to the first click on your lights. Everything else will work (turns, hazards, brakes) since they're on a different circuit.
Old May 28th, 2013, 01:06 PM   #7
Striking-A-Chord
You're right...nothing on the first click
When I unarm/disarm the alarm as well
Curious...how would changing the headlights affect this?
Maybe I checked the wrong fuse? I will check again when I come back from the hospital.
Thanks bro!
Let's Go Mets!
Old May 28th, 2013, 01:49 PM   #8
The name is Z
CrackerTeg's Avatar
Its possible something got grounded when you were hooking up the lights or something. You may have checked the wrong fuse. I just tried looking up a fuse box diagram online and nothing comes up as being labeled for the parking lights. Were it me, I'd pull out the fuses one by one that aren't painfully obvious, like IGN for example, until I found the culprit. Check the underhood fuse panel also.
Old May 28th, 2013, 02:20 PM   #9
Striking-A-Chord
Thank you so much man...I will let you know
Let's Go Mets!
Old May 28th, 2013, 02:39 PM   #10
The name is Z
CrackerTeg's Avatar
No worries bro.
Old May 29th, 2013, 12:49 PM   #11
Striking-A-Chord
It was the fuse. I was checking the wrong one
Fuse #4 was suppose to be 15A but was 10A (split) while Fuse #5 was 15A (checked that one before thinking it was #4)
everything is good now...thanks man
Old May 29th, 2013, 01:19 PM   #12
The name is Z
CrackerTeg's Avatar
No worries.
Old May 29th, 2013, 01:43 PM   #13
Hondaholic
Njzhitman88's Avatar
Now post up some pics of that beautiful thang bro
Njzhitman88 is offline   Reply With Quote Quick reply to this message
