Metallic Ping/Clink/Tink when the engine is hot :( - Honda Accord Forum : V6 Performance Accord Forums
Old June 27th, 2013, 09:26 PM   #1
Striking-A-Chord
StrikingAccord's Avatar
Question Metallic Ping/Clink/Tink when the engine is hot :(
Whenever my engine gets warm or hot it makes a metallic clink sound.
The sound is coming from inside the engine. It is not constant.
I just did an oil change and the level is fine.
What could this be? Could it need a valve adjustment?
Thanks!
2004 Accord EX V6 Coupe
Let's Go Mets!
StrikingAccord is offline   Reply With Quote Quick reply to this message
Old June 28th, 2013, 01:23 AM   #2
nathanhuu's Avatar
I just did a valve adj the other day and that didn't stop the sound. I think it's just common with the v6. I'm an auto
nathanhuu is offline   Reply With Quote Quick reply to this message
Old July 22nd, 2013, 03:52 PM   #3
Nuyorican2013's Avatar
Mine does the same was wondering what was going on also.
Nuyorican2013 is offline   Reply With Quote Quick reply to this message
Old August 2nd, 2013, 04:25 PM   #4
BLCKFLSH's Avatar
Anyone have a video? I don't hear any noises from my engine (V6).
BLCKFLSH is offline   Reply With Quote Quick reply to this message
Old August 3rd, 2013, 10:06 AM   #5
It could be some heat sheilds cooling, and the metal tinging as it is cooling could be what you hear.
200366HFP is offline   Reply With Quote Quick reply to this message
Old August 28th, 2013, 05:08 PM   #6
sirchadwick's Avatar
I get these sounds when the engine is cold. Until it warms up, it then goes away.
Sent from my SCH-I545 using Tapatalk 4
sirchadwick is offline   Reply With Quote Quick reply to this message
