Repair Switch Lamps - Honda Accord Forum : V6 Performance Accord Forums
Like Tree1Likes
  • 1 Post By Domi_no
Old July 9th, 2013, 06:05 AM   #1
Domi_no's Avatar
Repair Switch Lamps
Inspired by a post on Drive Accord, but I did not see one here. Both my sunroof and VSA lamps are burned out, so I wanted to create a thread for repairing the existing lamp, instead of replacing them.
Tools used for the job:
Philips screwdriver for the lower dash panel. Flat head side for bulb removal. Wire cutters to trim the wire leads on the new bulbs. Miniature flat head screwdriver to guide the wire leads onto the holder. Reading glasses for my old eyes.
&mpt=[CACHEBUSTER]">
Parts needed for the job, bulb and blue filter from Mouser Electronics.
JKL bulb part number 560-23, 1 for 0.39, 10 for 0.345.
JKL blue filter part number 560-39025A, 1 for 0.20, 10 for 0.18.
Blue filters are a bit darker than the one on the OEM lamp. Use if you want. Mine stayed in one piece, so I did not need them.
Time it took to make the repair was about 30 minutes.
1st ? loosen the lower dash panel enough to gain access to the switches for removal.
Links to help with this process:
Fog light installation document, starting on page 13.
YouTube Fog light installation link 1, link 2.
2nd ? Remove switches then remove each lamp.
&mpt=[CACHEBUSTER]"> &mpt=[CACHEBUSTER]">
3rd ? Separate the bulb from lamp base and from color filter.
Filter will come off under gentle persuasion with your fingernail. Take your time so it won?t tear.
New bulb is about 10% shorter, but the filter will fit with no issues.
4th ? Rebuilding the lamp.
Thread the new bulb into the base. Wrap the wire leads around the base, reverse to the removal of the old bulb. Test the lamp to make sure it lights up, and trim the leads so they can tuck back into the base channels.
Final ? Install the lamp back into the switches, and hook back up to test.
If all lights up, re-install the switches back into the dash panel, and re-install the panel.
I?ve read other posts that reference Radio Shack bulbs (272-1092). Nothing wrong with these bulbs, but I found the JKL bulbs are matching specs for voltage and current (14 volts, 0.40mA) as shown on Honda eStore. In addition to it matching, it should last longer than the Radio Shack bulb (10K average life hours to JKL?s 16K average life hours). Both have the same brightness of 0.15 MSCP. I bought 10 to help offset the shipping. Whether you buy 1 bulb or 100, the shipping is probably still the same due to Mouser only charges by weight, and these weigh almost nothing. Between my wife?s Acura TL-S and my Accord, I have plenty of bulbs to repair instead of replacing, saving me money down the road.
Honda eStore link.
Pricing shown below is from Honda eStore dated 7/7/2013
001 35300-SDN-A11 SWITCH ASSEMBLY, VSA OFF -- $11.60
003 35510-SDN-A11 SWITCH ASSEMBLY, HAZARD & PASSENGER SAFTEY RESTRAINT SYSTEM (SAFETY RESTRAINT SYSTEM (SRS)) INDICATOR -- $24.93
004 35600-SDN-A01 SWITCH ASSEMBLY, RIGHT HEATED SEAT -- $30.25
005 35650-SDN-A01 SWITCH ASSEMBLY, LEFT HEATED SEAT -- $30.25
006 35651-SDA-A01 TAPE -- $1.72
007 35830-SDN-A01 SWITCH ASSEMBLY, SUNROOF -- $28.32
008 35850-SDN-A01 BULB (14V 40MA) -- $4.48
009 35850-SDN-A11 BULB (14V 40MA) -- $4.48
010 35850-SDN-A01 BULB (14V 40MA) -- $4.48
011 35852-SDA-A11 BULB B, B (14V 70MA) -- $4.48
012 35852-SDN-A01 BULB (14V 40MA) -- $4.48
013 35871-SDA-L01 BULB, NEO-WEDGE (14V 80MA) -- $4.48
014 77625-SDA-A01ZA LID, SWITCH HOLE (GRAPHITE BLACK) -- $2.48
015 93903-22320 SCREW, TAPPING (3X12) -- $0.35
K3N likes this.
Old August 5th, 2013, 09:48 AM   #2
nice post i was wandering whymines didnt light up liket the rest of the buttons hehe
acc37 is offline   Reply With Quote Quick reply to this message
Old November 4th, 2016, 02:29 PM   #3
aHA! So those are all supposed to light up! My '07 EX-L is my first-ever Honda, so I'm starting from almost complete ignorance after years of driving other-brand cars. None of my assumptions and conclusions hold good any more, which is a little disorienting...posts like this help a lot, thank you!
Isocat is offline   Reply With Quote Quick reply to this message
