4 cylinders lost compression - Honda Accord Forum : V6 Performance Accord Forums
Old July 24th, 2013, 08:35 PM   #1
The Jester
Anyone want to guess the autopsy before I take apart the head to look for bent valves, stuck valves, exploded rods, broken heads, (any other possibilites?)
2 of the cylinders can hold pressure, and can hold plenty of pressure. Only cylinders 4 and 6 held.
Was messing with timing belt before this if anyone read that thread, had a few problems. Quite a few. Now I get to do an autopsy on the head before possibly doing a 32 swap or 35/37 heads, valves, crank, and rods.
Old July 25th, 2013, 07:53 AM   #2
You can hope its only bent valves after using that breaker bar.
200366HFP is offline   Reply With Quote Quick reply to this message
Old July 25th, 2013, 10:13 AM   #3
Honda Rookie
pbook4g5's Avatar
Was the motor ever running with the timing belt problems or were you just turning it over with a breaker bar? (Sorry, I don't know which thread you're referring to so I can't read it).
Old July 25th, 2013, 06:46 PM   #4
Slammed & Stunning
MatthewYu's Avatar
Swap over the heads for sale in the classifieds
Old July 25th, 2013, 08:56 PM   #5
BLCKFLSH's Avatar
Interference engine, means don't take the timing belt off, then start turning cams with the force you were describing. Hopefully you only bent valves.
BLCKFLSH is offline   Reply With Quote Quick reply to this message
Old July 30th, 2013, 10:58 PM   #6
The Jester
Thats about $400 out of my price range.
Taking apart the heads this week and hoping for the best.
Else, would the best option for power to be dropping in a j32 whole block?
or
j30 block, 3.5 IM + TB
Would consider the heads in the classifieds, but a whole new block is $700 + ship, those heads themselves are $600 and not sure if they include valves. Will have to check to see that I didn't bend a rod.
