Camshaft removal - Honda Accord Forum : V6 Performance Accord Forums
Old August 2nd, 2013, 05:23 PM   #1
The Jester
Camshaft removal
Having some trouble getting the heads off of my engine, along with being able to remove the camshaft bolts.
Is there any guide to this or a method to lock the cams in place that I am overlooking? Need to replace at minimum the valves if not entire heads.
Old August 2nd, 2013, 05:33 PM   #2
impact gun is going to be your best bet.
Old August 2nd, 2013, 06:10 PM   #3
The Jester
Any idea what kind of torque? Have a few hundred on a regular gun but looks like I need a 90* impact for the rear head. Going to need to lock the gears for an impact, and do I even need to remove the cams to remove the heads?
Tempted to bump start the bolts loose like the crankshaft bolt, not sure if that would damage the seals though.
Edit: rear head removed, only one shop in town has spanners, this could get difficult.
