New gasket or valve cover? - Honda Accord Forum : V6 Performance Accord Forums
Old November 6th, 2013, 02:28 PM   #1
Czechopino
vasekvi's Avatar
Is there a gasket I can replace inside here or do I need a new valve cover? I'm not missing anything am I?
Sent from my AT&T Galaxy S4 using Tapatalk Pro
My SSM Sedan Mod Thread
Old November 6th, 2013, 03:51 PM   #2
Pcv valve
Old November 6th, 2013, 04:12 PM   #3
Czechopino
vasekvi's Avatar
I'm missing one?
Old November 6th, 2013, 04:37 PM   #4
yes you are. should have posted a few weeks ago. I had an extra one I could have given you. Let me see if I have another one. they are like 30 bucks.
Old November 6th, 2013, 04:37 PM   #5
bozos_si's Avatar
Yes. your missing this. I have 2 for sale.
Honda Accord Pilot Acura TSX PCV Valve OES Genuine Used | eBay
Old November 6th, 2013, 04:40 PM   #6
bozos_si's Avatar
You can see on this listing what it looks like installed on the motor.
Honda Accord 03 07 Engine Motor Long Block Assy 3 0L V6 137K MI 2005 A305 | eBay
Old November 6th, 2013, 05:48 PM   #7
Czechopino
vasekvi's Avatar
Dammit. So when I had my engine swapped last year they never put this on. Would this cause a CEL for a vacuum leak?
Old November 6th, 2013, 05:53 PM   #8
bozos_si's Avatar
I'm sure it would.
Old November 6th, 2013, 05:56 PM   #9
Czechopino
vasekvi's Avatar
Thanks for the info guys. I'll be picking this up ASAP.
Old November 6th, 2013, 05:59 PM   #10
no CEL or Vacuum leak. Just spraying all over the place. That valve I think filters positive pressure air out.
Your P/S fluid also looks low
Old November 6th, 2013, 06:41 PM   #11
bozos_si's Avatar
I believe the pcv valve is part of the vacuum system. This will explain it.
What is the PCV valve and what does it do? — Yahoo! Autos
