06 accord v6 3.0 engine compared to 06 odyssey 3.5 engine - Honda Accord Forum : V6 Performance Accord Forums
Old February 2nd, 2014, 05:01 PM   #1
bozos_si's Avatar
So my question is are the intake runners and fuel rails the same on these 2 motors? I am planning on swapping them and I have upgraded fuel rails on my accord and port and polished intake runners. I am hoping to be able to swap them. If anyone has any info please comment.
Old February 2nd, 2014, 08:34 PM   #2
accord325's Avatar
From what I can see the port shape is different on the runners, to the heads. Could be wrong but they look differnt. I have a set of MDX 3.7 heads in my garage and the runners port shape look the same. Not sure about the fuel rails. Check this link
Weapon-RŪ - Honda Odyssey 2005 Intake Manifold Thermal Gasket
Old February 3rd, 2014, 04:41 AM   #3
bozos_si's Avatar
They look a little different but I am hoping all the bolts line up. I am pretty sure that they could be swapped I just want to make sure. I am planning on keeping the DTB manifold now too so I am just hoping everything bolts up. I had to redo the fuel lines so if I cant reuse my p2r fuel rails I might have a problem.
Old February 3rd, 2014, 08:04 AM   #4
accord325's Avatar
I'm sure they will bolt up but the port shape is much different. Do whatever you want, sure the flow will be horrible.
Old February 3rd, 2014, 10:46 AM   #5
bozos_si's Avatar
yes but is that head side or is that intake manifold side? The main thing I am worried about is the fuel rails. I can always have paul port and polish the runners again.
Old February 3rd, 2014, 07:49 PM   #6
bozos_si's Avatar
Someone has to have some good info on this. There has to be guys that have done this swap that will know the differences.
Old February 4th, 2014, 04:32 AM   #7
bozos_si's Avatar
Paul just told me everything will bolt up fine.
