Tire leaning - Honda Accord Forum : V6 Performance Accord Forums
Like Tree1Likes
  • 1 Post By accord325
Old April 19th, 2014, 02:41 PM   #1
Tire leaning
Im new to this so please bare with me. I just had my front & rear sway bar installed with an alignment. Now my rear wheels are leaning in on then top. What can I doto correct this?
gasmask34 is offline   Reply With Quote Quick reply to this message
Old April 19th, 2014, 02:46 PM   #2
camber kit?
Old April 19th, 2014, 04:22 PM   #3
accord325's Avatar
The sway bar install should not have effected the Camber. Did you lower the car, and what sway bars did you install ?
Old April 19th, 2014, 04:31 PM   #4
sway bar: 27.2 front, 20 rear, the front is lowered 1.3 inches, didn't lower the rear... speaker box, amps, batteries are in the trunk
Old April 19th, 2014, 04:34 PM   #5
Originally Posted by thisaznboi88 View Post
camber kit?
which camber kit is needed? I see a few on ebay but don't know which one to get...
Old April 19th, 2014, 04:59 PM   #6
spc, eibach, j power, ingalls
Old April 19th, 2014, 05:07 PM   #7
accord325's Avatar
A camber kit will solve the issue, just trying to figure out why the camber was effected.
Carz&Gunz likes this.
Old April 19th, 2014, 05:14 PM   #8
[QUOTE=thisaznboi88;2376697]spc, eibach, j power, ingalls[/QUOTE will I need 2 per side (4 total)?
Old April 19th, 2014, 05:30 PM   #9
if weight affects the camber then that's y...got a lot of stereo equipment in that car.
Old April 19th, 2014, 06:30 PM   #10
Do u have 200lbs worth? The first 2 are upper arms the other 2 choices are the lower arms so 4 arms total
Old April 19th, 2014, 06:38 PM   #11
accord325's Avatar
So u added all the weight at the same time as your sway bars ? Your making it seem like u did the sway bars and alignment then the camber was off. 200lbs will lower the car and the camber.
Old April 19th, 2014, 08:56 PM   #12
1st i lowered the front 1.3 inches, then the system, then the rear sway bar (2 weeks ago) today the front sway bar and alignment...I don't think they did an alignment because I looked at the bolts and nut and they haven't been touched... Monday they will get a call...
Old April 19th, 2014, 08:57 PM   #13
did u get a print out?
Old April 23rd, 2014, 07:16 PM   #14
no, I didn't. when there Monday and they did the alignment... camber kit should be here Friday...
Old April 24th, 2014, 12:21 PM   #15
nismoasfuh's Avatar
no one uses the wicked camber kits anymore?
Old April 24th, 2014, 04:22 PM   #16
accord325's Avatar
You should, I had a shop put the car on the lift a came back saying it was done. I asked for the print out and the guy had a confused face. He stuttered and said let me go find it. He came back and asked me to wait for it. I then see them putting the sensors on the wheels, 25 min later a print out was finally given to me. LOL
Long story short, I now stand directly behind my car in the outside the bay and watch them. I know they hate me but I dont give a Fu$K. Try to screw me over and trust is forever lost.
Point A to B
NA.... Till I Spray
Old April 25th, 2014, 05:31 AM   #17
Carpe Diem
ikethegreat's Avatar
I do the same exact thing whenever I take my car somewhere for work. I don't care if it pisses them off. With the customer watching, they will be much less likely to cut corners.
Old April 28th, 2014, 05:22 PM   #18
got camber kit in Friday call the shop to find out how much they charge to install w/an alignment. camber kit installed for $179.00 an alignment was $79.00.... I jacked that car up an pulled the rear wheels and 20 minutes later they were on... alignment was $50.00... I did use the wicked camber kit
Old May 10th, 2014, 05:12 PM   #19
Sorry, Nothing to add but I really need help and can't start a thread until I've posted 10 times. This is likely bad form, and I apologize, but have no options at this point. (Post 1) Thanks,
Rob ;-(
rcrosby257 is offline   Reply With Quote Quick reply to this message
Old May 10th, 2014, 05:13 PM   #20
Sorry, Nothing to add but I really need help and can't start a thread until I've posted 10 times. This is likely bad form, and I apologize, but have no options at this point. (Post 2) Thanks,
Rob ;-(
Old May 10th, 2014, 05:14 PM   #21
Sorry, Nothing to add but I really need help and can't start a thread until I've posted 10 times. This is likely bad form, and I apologize, but have no options at this point. (Post 3) Thanks,
Rob ;-(
Old May 10th, 2014, 05:15 PM   #22
Sorry, Nothing to add but I really need help and can't start a thread until I've posted 10 times. This is likely bad form, and I apologize, but have no options at this point. (Post 4) Thanks,
Rob ;-(
Old May 10th, 2014, 05:15 PM   #23
Sorry, Nothing to add but I really need help and can't start a thread until I've posted 10 times. This is likely bad form, and I apologize, but have no options at this point. (Post 5) Thanks,
Rob ;-(
Old May 10th, 2014, 05:16 PM   #24
Sorry, Nothing to add but I really need help and can't start a thread until I've posted 10 times. This is likely bad form, and I apologize, but have no options at this point. (Post 6) Thanks,
Rob ;-(
Old May 10th, 2014, 05:17 PM   #25
Sorry, Nothing to add but I really need help and can't start a thread until I've posted 10 times. This is likely bad form, and I apologize, but have no options at this point. (Post 7) Thanks,
Rob ;-(
Old May 10th, 2014, 05:18 PM   #26
Sorry, Nothing to add but I really need help and can't start a thread until I've posted 10 times. This is likely bad form, and I apologize, but have no options at this point. (Post 8) Thanks,
Rob ;-(
Old May 10th, 2014, 05:19 PM   #27
Sorry, Nothing to add but I really need help and can't start a thread until I've posted 10 times. This is likely bad form, and I apologize, but have no options at this point. (Post 9) Thanks,
Rob ;-(
Old May 10th, 2014, 05:20 PM   #28
Sorry, Nothing to add but I really need help and can't start a thread until I've posted 10 times. This is likely bad form, and I apologize, but have no options at this point. (Post 10) Thanks,
Rob ;-(
Old May 14th, 2014, 12:20 PM   #29
wow this guy is serious! ^^
yeah the best thing is to stay by the car when getting your alignment. the place i go to there is a section where you can "watch" whats being done to your car. mind you im in toronto. how much did your rear camber kit ended up costing you?
sunny416 is offline   Reply With Quote Quick reply to this message
Old May 15th, 2014, 05:33 PM   #30
I got the wicked camber kit off ebay for $89.00 free shipping
