Car Misfires and runs rough below 2500RPM + Limp Mode - Honda Accord Forum : V6 Performance Accord Forums
Old May 8th, 2014, 09:03 AM   #1
So i just picked up a 2004 accord v6-6. 325K Kilometer or 203K Miles for the imperial people. The car was not running the best.
The problem i have its that the car sounds rough like a diesil below 2500rpm and is silky smooth after.
Also, once the car is warm, it will loose power and go into limp mode (highly restricted power by ECU)
The codes i got were P0000, P0300, P0305, P0306.
I have cleared them and they have came back.
I pulled the sparks today and found the front bank (4,5,6) was running lean. Plugs were all white all over. (1,2,3) looked normal. brown with a spec of white where it ignites.
Any help is appreciated.
Old May 8th, 2014, 07:26 PM   #2
Honda enthusiast
michaellowrider's Avatar
Congrats on the 6-6. The coils are probably bad on at least cylinders #5 and #6. Unplug each coil momentary to see which one(s)have failed. Worst case its the valves, check the compression.
Old May 8th, 2014, 08:02 PM   #3
^ move them around and see if it change. If you need coil packs I have some spares
Old May 9th, 2014, 01:41 AM   #4
ive swapped some coil packs with another car and it doesnt misfire code. however, i threw back the old ones on and car died driving later today. i was making good power until exhaust vtec and then a couple minutes later, car will not idle. Car will refuse to start now as well.
Old May 9th, 2014, 01:45 AM   #5
also, im thinking of giving up this engine for a j32 swap. opinions??
