v6 idle rough on start up - Honda Accord Forum : V6 Performance Accord Forums
Like Tree2Likes
  • 1 Post By simione
  • 1 Post By oraclem19
Old June 20th, 2014, 05:26 PM   #1
bozos_si's Avatar
Since I put my PCD's and exhaust on over a year ago I have noticed that my car has been idling rough on start up. Once it warms up it goes away. Almost sounds like its got cam's. Anyone else have this happening to them? Today it actually through codes. Saying that it was misfiring on all cylinders when I started it up. But like I said after a couple minutes it goes to idling normal and it runs fine.
Old June 20th, 2014, 05:38 PM   #2
It is normal. The motors actually misfire themselves to heat the cats up quicker. The thickness of the metal of the stock exhaust components and the cats keep all of this quiet. The codes are not a normal part of it, though
Old June 20th, 2014, 06:01 PM   #3
bozos_si's Avatar
Hmm. This is the only time it came on. If it happens again any idea on what it could be?
Old June 20th, 2014, 06:11 PM   #4
I've read in various threads that it could be valves needing adjustment or bad coils.
3.0UALLKNOW likes this.
Old June 20th, 2014, 07:15 PM   #5
The Jester
This.
Car had one valve far enough off that it sounded like a Harley before a valve tune. After it diminished. However with MDX cams it does still sound a bit odd.
thisaznboi88 likes this.
Old June 20th, 2014, 08:44 PM   #6
bozos_si's Avatar
But was it just on start up? It runs and sounds normal after a couple minutes.
Originally Posted by oraclem19 View Post
This.
Old June 20th, 2014, 09:30 PM   #7
The Jester
pretty normal after warmup, until I gas it then it goes back to sewing machine until cruising at which point its silent.
Scary silent too. I'm also using 20wt race oil Redline in 120* heat.
Old July 4th, 2014, 03:26 PM   #8
Ryguy1992's Avatar
Mine does the same thing except it doesn't code. I love it
Ryguy1992 is offline   Reply With Quote Quick reply to this message
Old July 9th, 2014, 12:12 AM   #9
nickisepik's Avatar
Hey yea I've got the same thing goin on. I'm gonna do a valve adjustment and check (maybe replace since I'm at 120k) all my coils.
nickisepik is offline   Reply With Quote Quick reply to this message
Old July 9th, 2014, 04:29 AM   #10
bozos_si's Avatar
Is it happening frequently? Mine just came on again yesterday.
