Left side a/c vents wont cool - Honda Accord Forum : V6 Performance Accord Forums
Old July 19th, 2014, 08:04 PM   #1
Wingdreamer
wingdreamer's Avatar
Have the dreaded problem with my a/c vents. Both the right center vent an right passenger vent blow nice cold air. The left center vent and the far left vent blow basically room temp. I have read up on this forum, and others, and also found the Honda service bulletin indicating that the system may be low on refrigerant. Off to my buddies shop where we evacuated the system. It was down about 2 oz.
Recharged it with 19.4 oz refrigerant (as noted on the sticker by the high and low side valves).
Started the car and set it to recirculate and temp to low (has dual climate control).
Outside air temp was 70F:
I got 37F out of the far right vent, 42F on the center right vent, 67F on the center left vent and 70F on the far left vent.
If I set controls to full heat on vent, all vents blow around 140F, so heat is not great either.....
Suggestions?
2006 Accord EX V6 3.0 with Navi. My 4th Accord, die hard Honda fan! My other Honda is a GL1800 Goldwing!
wingdreamer is offline   Reply With Quote Quick reply to this message
Old July 19th, 2014, 08:20 PM   #2
The Jester
Keep the window open.
Old July 20th, 2014, 08:55 AM   #3
Wingdreamer
QUOTE=oraclem19;2423033]Keep the window open.[/QUOTE]
Wanna tell my wife that on a hot sticky day?
Old July 21st, 2014, 09:04 AM   #4
dieing blower unit perhaps?
Jasmine6-6 is offline   Reply With Quote Quick reply to this message
Old July 23rd, 2014, 10:20 AM   #5
Wingdreamer
no, good forced air, cabin filter is clean as well...
