Recurring P420 code w/ freeze frame data - Honda Accord Forum : V6 Performance Accord Forums
Old July 27th, 2014, 02:28 PM   #1
So my car has a recurring P420 code. Its been on for about 6 months. This weekend I had a new starter put in because it was going out, also cleaned the air filter box out, cleaned the IAT sensor, and the air intake tube and replaced the air filter. Afterwards, the CEL went off and my friend Amber (who is a mechanic) reset the maintenance light so it would go off.
We drive from Denver to Montrose, CO yesterday to see the Black Canyon of the Gunnison. Before we left we poured some sea foam through the intake and some in the gas tank to clean everything out in the engine and gas tank and injectors. She ran like a champ most of the day, till halfway back to Denver the CEL light came on again and the idle was a bit rough.
Hooked the obdII scanner up and it gave me the code plus freeze frame data of the engine when the fault occurred.
anyone know whats going on here?
WyattEarp is offline   Reply With Quote Quick reply to this message
Old July 27th, 2014, 04:02 PM   #2
accord325's Avatar
Don't quote me on this but I think your front bank cat (or one of them) is taking a crap.
Old July 27th, 2014, 04:56 PM   #3
i looked under my car, all it shows is one catalytic converter. is that all I need?
Old July 28th, 2014, 12:17 PM   #4
anyone else?????
Old July 28th, 2014, 12:40 PM   #5
His a 4 banger so yes the cat under your car
Old July 28th, 2014, 02:33 PM   #6
accord325's Avatar
Lol, didn't read his sig.
Old August 3rd, 2014, 03:24 PM   #7
That freeze frame data is meaningless for that code. You need to compare your o2 sensors to see if they are switching the same. If so then your probably will need a cat.
Beefcake17 is offline   Reply With Quote Quick reply to this message
Old August 25th, 2014, 08:14 PM   #8
cat replaced. code gone.
Old August 26th, 2014, 08:56 AM   #9
accord325's Avatar
Good to hear everything worked out and we could help
Old August 26th, 2014, 10:03 AM   #10
bozos_si's Avatar
How many miles you have on this? I have rarely heard of a cat going bad unless the car was super old or super high in miles.
