Radiator question - Honda Accord Forum : V6 Performance Accord Forums
Like Tree2Likes
  • 1 Post By simione
  • 1 Post By simione
Old September 4th, 2014, 01:47 PM   #1
bozos_si's Avatar
Radiator question
For our V6 6 speed cars is there any aftermarket radiator out there? I have been looking but only seem to find ones for automatics. Am I just not looking in the right place?
Old September 4th, 2014, 02:00 PM   #2
Performance Aluminum Radiator for 2003 2007 Honda Accord 3 0L V6 at MT New | eBay
Here's the one I have. No issues so far in 6 months
Old September 4th, 2014, 02:27 PM   #3
bozos_si's Avatar
That one looks a little wider than stock. Were you able to use your oem brackets?
Old September 4th, 2014, 02:27 PM   #4
Originally Posted by simione View Post
Did the oem fans bolt up or did you switch to aftermarket slim fans?
04 Accord 6-6 Coupe
13s no matter what hp I have
Just an All Motor J30...
Zach @ YCU Dyno Tuning
Old September 4th, 2014, 02:44 PM   #5
Everything bolted right up. It is a little wider than stock, but everything fit just fine
Atlas.46 likes this.
Old September 6th, 2014, 07:10 AM   #6
DAT Dewd from Dallas MANG
CSF makes a radiator that is pretty good.
the mount points for the fan have to be relocated.
my radiator I got from Paul...
I have seen this ebay one for about 6 months now...
How do you like it Simione?
Does it hold more water?...how much bigger is it then stock?...
and did you notice any temp differences once you installed it?
Old September 6th, 2014, 08:21 AM   #7
I like it. if i remember correctly,it took 1.75 gallons of coolant to fill.
this will give you an idea of how much larger it is. the pcd almost touches the fan
&mpt=[CACHEBUSTER]">
accord325 likes this.
