Fuel Pump, Fuel Relay? Trouble starting! Help! - Honda Accord Forum : V6 Performance Accord Forums
Old September 24th, 2014, 09:35 PM   #1
Hello,
My 07 Accord has has some trouble starting recently. This week has been the worst.
Occasionally it's taking longer to start them normal. I crank it and it takes a few seconds to turn over. Today it cranked for a few seconds then it was silent for a second, then it turned over and started. The rest of the day it started fine.
It has 150,000 miles.
The battery is fine. We are going to try to replace the fuel pump relay this weekend. I'm not noticing any other problems. It's just taking a few seconds to start and it's not all the time.
I put in fuel injector cleaner and filled it up with the higher octane gas this time too.
Any suggestions?
dec30 is offline   Reply With Quote Quick reply to this message
Old September 24th, 2014, 09:45 PM   #2
check your ground
Old September 25th, 2014, 10:12 AM   #3
accord325's Avatar
You can have your starter tested while still on the car, at an autoparts store. The car made no sound when you turned the key ? I would also check grounds
