transmission weird sound - Honda Accord Forum : V6 Performance Accord Forums
Old October 24th, 2014, 02:00 PM   #1
My transmission make a weird sound but i am not able to figure from where this sound is comming from.Just wonder if someone had a similar sound? it does not following the RPM of engine so if I am at 60 mph and I put the car on neutral the sound Stay at the same level. If i lift the the car only on the driver side it does not making any sound. The axle shaft is also not align correctly but I don't know if it could be a problem or if it's normal? There is the video. Transmission weird sound Accord V6 Manual 6 speeds - YouTube
Alex
alexis444 is offline   Reply With Quote Quick reply to this message
Old October 25th, 2014, 04:54 AM   #2
M90SC Boosting 13PSI
NVA-AV6's Avatar
Check your 1/2 shaft bearing. You will have to remove the pass side shaft then the 1/2 shaft from the block.
Old October 26th, 2014, 08:56 PM   #3
thanks Paul thats the plan now!! Just realize the A/C compressor is making noise too so dosent help for the noise.
Old October 27th, 2014, 04:54 AM   #4
NVA-AV6's Avatar
Remove the accy belt for testing, if your battery is in good shape you can easily run 20min without the alt being run.
