LED issues - Honda Accord Forum : V6 Performance Accord Forums
Old November 12th, 2014, 05:29 AM   #1
LED issues
I have gone through a few sets of LED lights in the brakes. Its wierd and I cannot figure it out as to why, but almost as soon as they are installed, they blow. I have tried cheap ones and just blew a set of the cree Led's . Anyone else have this issue? I am going to look at the wiring to see if there is an issue, it looks like the spoiler is aftermarket and could be the issue, it is like the left and right sides backfeed each other.
Standard bulbs dont do it, and I even put resistors in the brakes to see if that was the issue, and it blew anyway...
Anyone have this issue?
hightechredneck is offline   Reply With Quote Quick reply to this message
Old November 23rd, 2014, 02:03 PM   #2
just went through my own headache with LEDs
http://www.v6performance.net/forums/...her-relay.html
if i try and put LEDs in front turn signals with non modified Flasher Relay, all taillights light up
you should check the fuse and see what other components are tied into the brake stop light
for the taillights on, turn signals, etc. is just one single fuse under the hood
Honda def. didn't make it modder friendly nor did they have to esp. for us 4 doors
good luck and whar load resistor do you have? it has to be within wattage range to work correctly
does it get extremely hot meaning its doing its intended purpose?
the ones i got are pilot and came with very thin pos/neg wires and i am swapping them out once i get all wattages in order
