Misfiring-05 Accord V6 - Honda Accord Forum : V6 Performance Accord Forums
FAQ Members List Calendar Mark Forums Read Insurance
Like Tree1Likes
  • 1 Post By thisaznboi88
LinkBack Thread Tools
Old January 20th, 2015, 02:06 PM
Question Misfiring-05 Accord V6
I have an 05 Accord V6 EX 6MT. I was driving locally a couple days ago and on an highway on ramp i decided to put petal to the metal, and then i noticed i do not have the power i usually do. I also noticed that my check engine light turned on (not flashing) a couple minutes later after i was on the highwy. I took it to advance auto to have the codes checked out. It was misfiring from cylinders 1-6 and also random misfire. I went home and checked all ignition coils. I found that they were all good after switching them around, but i noticed cylinder 1-3(towards firewall) were always not firing even after i put the good coils in them. I then tested the ignition wires running to the top of the coils, all 6 cylinders had same voltage. I assumed everything is good in the ignition system.
I am no expert in automotives, and have tried searching all over. I cant loose this car so I am asking for help. What should a test next and how??
weatherman110 is offline   Quick reply to this message
Old January 20th, 2015, 02:13 PM
stalloutboy's Avatar
Wet and dry compression test. It's super easy to perform and you can rent a compression tester at your local AutoZone.
stalloutboy is offline   Quick reply to this message
Old January 20th, 2015, 02:23 PM
Any other recommended tests?
Old January 20th, 2015, 02:27 PM
That is all I can think of off the top of my head. It sounds like the valves to me though.
Old January 20th, 2015, 02:47 PM
did you check the sprak plugs while you were checking the coils?
thisaznboi88 is offline   Quick reply to this message
Old January 21st, 2015, 06:07 AM
Carpe Diem
ikethegreat's Avatar
Spark plugs would be the first thing I'd check.
ikethegreat is offline   Quick reply to this message
Old January 21st, 2015, 06:15 AM
M90SC Boosting 13PSI
NVA-AV6's Avatar
When you were trying to "Pedal to the Metal" did you hit the gears properly or did you accidentally hit 2nd instead of 4th or 1st instead of 3rd?????
NVA-AV6 is offline   Quick reply to this message
Old January 21st, 2015, 05:41 PM
NVA-AV6 i went through one gear (3rd) doing that and then just shifted to 4th no over-revving.
ThisAZNboi88 I havnt checked the plugs, that's the last simple thing i havn't done. I will do that tommorow.
I have rented a compression tester and will also do that tommorow. I have been driving it around, and noticed my gas mileage is also terrible.
Old January 21st, 2015, 06:10 PM
make sure the plugs are NGK or DENSO
NVA-AV6 likes this.
Old January 22nd, 2015, 11:25 AM
I have just finished taking out all spark plugs, which show that they are all good(all look the same). They all just have a little bit of white on them. My dry compression test came out to be strange.
Dry Test: Cylinders 1-3 are around 90PSI 4-6 are around 120 PSI
Wet Test: Cylinders 1-3 are around 100-110 4-6 are around 125-130
Obviously 1-3 have some type of problem. Could this be a head gasket?? Idk how to test for that i dont have an air compressor.
I have done all the maintenance on this car at 95,000 miles and right now i'm at 149000. I put NGK's when i changed all my belts and water pump. I also have an AEM V2 cold air intake.
Old January 23rd, 2015, 05:41 AM
NVA-AV6's Avatar
Do you still have stock pre-cats? If so I expect the rear cat let go and the catalyst just sand blaster your rear bank of cylinders. If you can lay hands on a bore scope you can pull the rear primary O2 sensor and look in thru that hole at the catalyst and see if it is intact.
