Clutch pedal sticking - Honda Accord Forum : V6 Performance Accord Forums
Old March 8th, 2015, 07:38 PM   #1
Hondabob8o8's Avatar
I have a 2006 Honda Accord 4 dr 6 speed v6 I been having problems with my clutch this happens only after high rev shifts and more when it's really hot out .Vehicle will not go into gear and some time the clutch pedal get stuck to the floor to the point I have to to lift it with my foot other times I'll be at a light and the car will just not go into gear any one else have these problems. I got 60,000 miles
Hondabob8o8 is offline   Reply With Quote Quick reply to this message
Old March 8th, 2015, 07:40 PM   #2
sounds like mine when the clutch was starting to go out, not trying to scare you but mine did the same thing and finally one day driving normally went to shift into second at about 3500rpm book, pressure plate went out. Got a whole new clutch job done and never had the problem since
Nickdees is offline   Reply With Quote Quick reply to this message
Old March 9th, 2015, 04:33 AM   #3
Domi_no's Avatar
2006, V6, 6-speed, 135K miles. I've had the same issue for over a year now. Original clutch, strong with no slips, but from time to time the pedal does sticks for a pump or two after a 4K - 5K gear change. Mechanic can't duplicate it, so he didn't want to work on it. I agree that is could be the pressure plate going out.
Old March 9th, 2015, 07:10 AM   #4
....I never had that in 140,000 miles on my 6M.
.....then again - freeway on-ramps excluded - I resisted the urge to bounce RPM off the rev limiter. Great car. Dog**** clutch action (the infamous slave cylinder restrictor valve pertains).
ez
ezshift5 is offline   Reply With Quote Quick reply to this message
Old March 9th, 2015, 07:42 AM   #5
accord325's Avatar
Sounds like the PP to me.
Old March 9th, 2015, 10:47 PM   #6
could be the master cylinder? mine was toast and i replaced it and the pedal action was fine. though i also think the pressure plate could also be a culprit if this only occurs at high rps. I have the same issue, only with high rev shifts will my pressure plate act up. have to give a few pumps before it works properly
rave93 is offline   Reply With Quote Quick reply to this message
Old March 10th, 2015, 07:53 AM   #7
probably pressure plate, try swapping out the fluid and see if that helps.
Old March 10th, 2015, 02:18 PM   #8
AJB
I have the same issue one time. But I don't rev the car that much unless I have too. When the clutch goes, I'll address it then. Not going to worry about ti now if it is the pressure plate. I mean once the damn thing is apart mine as well do the entire job. Mine has 160k on it.
AJB is offline   Reply With Quote Quick reply to this message
Old April 8th, 2015, 03:25 PM   #9
I'm going to replace clutch pressure plate and bearing looking to get something besides Oem any body have any suggestions not looking to break the bank I heard exedy is a good brand ,and do you guys think a need to replace flywheel
Old April 8th, 2015, 04:06 PM   #10
Luks clutch is 150 some where. you need to swap out the dualmass flywheel also
Old May 6th, 2015, 09:55 AM   #11
AJB
How much does it cost for a typical clutch job with the pressure plate and possibly the flywheel?
Old May 7th, 2015, 12:57 AM   #12
sounds like pressure plate to me, im having the same problem. i just dont drive too hard and ill wait till i run out of clutch disk
Old May 7th, 2015, 06:58 AM   #13
AJB
yeah, I'm waiting on the same thing. I have 163k on it now.
Old May 15th, 2015, 12:58 PM   #14
same problem.
I have 4cyl. 5 speed. but getting on the highway is questionable at times. I have to force it in, when traffic is catching up. Only happens at high RPM and repeats when I've been sitting in trafic working the clutch.
I am planning to change the fluid.
otherwise it works perfect, when im gentle.
175.000km
Ex-Rrrr is offline   Reply With Quote Quick reply to this message
