Factory Camber and Toe Specs? - Honda Accord Forum : V6 Performance Accord Forums
FAQ Members List Calendar Mark Forums Read Insurance
LinkBack Thread Tools
Old March 28th, 2015, 03:33 PM
Calm like a bomb
StevilKnievel's Avatar
Does anyone know the factory spec for an 05 AT6 Coupe? I'm getting my rims installed soon and getting a 4 wheel alignment done. I'd like to know the spec before I get the "it's fine don't worry about it" song and dance because they don't want to do it. I can visibly see that the LR wheel is at a more negative camber angle than the others. Thanks in advance!
EDIT: I searched the forums first but nothing with specific numbers popped up. Also this is for 205/60r16 with factory ride height.
StevilKnievel is offline   Quick reply to this message
Old March 29th, 2015, 08:21 AM
Camber angle:
Front:
DX ('03-05) and VP models: 0 03 '45 '
DX ('06), LX, LX-P, SE, EX, EXL models:
0 degree 00 '45'
Maximum difference between the right and
left side: 0 45 '
Rear:
DX ('03-05) and VP models: -0 50 '30 '
-100'30'
Front toe-in: 02 mm (01/16 in.)
Rear toe-in: 22 mm (1/161/16 in.)
06 coupe silver 6 speed
ypsibird is offline   Quick reply to this message
Old March 30th, 2015, 06:45 AM
Calm like a bomb
Awesome. Thank you for the info.
Old March 30th, 2015, 01:39 PM
You're welcome. And to be complete I should have included the specs for caster as well.
Caster angle:
DX ('03-05) and VP models: 310'45'
DX ('06), LX, LX-P, SE, EX, EXL models: 315'45'
Old April 2nd, 2015, 07:20 AM
Calm like a bomb
This post is assuming all components are stock.
So if I'm understanding this correctly, the rear camber is not adjustable. Or perhaps it is but not something a monroe or pep boys monkey will adjust. Supposing it is not adjustable and the camber is off what would be the most likely cause? Stabilizer? Hub? I wouldn't think a worn strut could cause that either. Just curious. I feel like I'm about to get my pants pulled down and put over the barrel.
Old April 3rd, 2015, 09:19 AM
Calm like a bomb
Bump. Anyone?
