Cheapest place to get an OEM Honda cat? - Honda Accord Forum : V6 Performance Accord Forums
Old April 16th, 2015, 09:36 PM   #1
Where's the cheapest place to get an OEM Honda Catalytic Converter for my 03 Honda Accord LX 4 door 2.4 dohc, 5 spd manual?
the Walker OE replacement I had installed in August is throwing p0420 again and the light is on. attempts to reset the computer with an obd-II are unsuccessful.
I'm gonna buy a new cat and o2 sensors because I have emissions coming up at the end of May in Denver, otherwise I can't renew my registration.
WyattEarp is offline   Reply With Quote Quick reply to this message
Old April 17th, 2015, 06:55 AM   #2
Go to RockAuto dot com
You can't go wrong with those guys, I've been using them for years. Get everything in one place.
Usually for the price of cheap aftermarket parts, you can buy much better parts from Rockauto, even including shipping.
HTH
ctandc is offline   Reply With Quote Quick reply to this message
Old April 17th, 2015, 04:21 PM   #3
thanks! will check them out.
Old April 17th, 2015, 06:19 PM   #4
J35 _ 5-Speed A/T
WHEEELMAN's Avatar
Rockauto does not carry OEM parts, only Aftermarket.
You are gonna have to find an online dealer with the cheapest price.
But, if you have a hookup at your local junk yard, then...
Old April 18th, 2015, 01:39 PM   #5
no hookup at junkyards.
Old April 18th, 2015, 03:33 PM   #6
05accord6spd's Avatar
Why do you need OEM cats what are you trying to spend
Old April 19th, 2015, 07:35 PM   #7
because I live in Denver number one. They have pretty stringent emissions testing. no I'm not moving out of Denver. I have a great situation and it works for me.
My converter is bad. I already bought a piece of junk aftermarket one and it's still causing my light to come on. I can't pass with that damn light on.
So I'm just going to spend the money and buy the OEM and some O2 Sensors and be done with it.
as cheap as possible.
Old April 19th, 2015, 08:32 PM   #8
The Jester
If the v6 and yours use the same ones I may have one.
Alternatively you may be able to just use a defouler spacer or just aluminum tape over the holes and pinprick through it. Or copper rtv in most of them. Or there are simulators that will pretend to be an o2.
Old April 21st, 2015, 09:03 PM   #9
yes, the v-6 and 4 cylinder cat are the same. is it brand new?
Old April 22nd, 2015, 07:43 AM   #10
I've never had trouble passing the visual and the sniffer test with aftermarket cat converters. Wondering if the code you're throwing is something to do with the O2 sensor and not the cat?
I know RockAuto doesn't carry Honda / OEM - but I don't see finding an OEM part that cheap at all....thus the aftermarket cats available for just about every make / model of car.
Magnaflow makes a direct fit replacement as well.
Old April 22nd, 2015, 09:08 AM   #11
stalloutboy's Avatar
Just get a defouler? Or is that not an option for you
stalloutboy is offline   Reply With Quote Quick reply to this message
Old April 22nd, 2015, 09:46 AM   #12
Honda enthusiast
michaellowrider's Avatar
Defouler on the 2nd O2 and a smog tech with a bad back? Or is that not an option for you
Old April 22nd, 2015, 09:49 AM   #13
Honda enthusiast
Totally sucks that the walker is giving you issues. Are our cars too sensitive for aftermarket cats? I just clear the code and drive around before smog lol
Old April 22nd, 2015, 04:28 PM   #14
I don't even know what a defouler is.
If I clear the code, it comes back on 15 minutes later. can't get it to stay off long enough to go get an emissions test.
and where is it that you live at? Same state and city? Different locales have different standards for emissions testing.
Old April 22nd, 2015, 06:03 PM   #15
http://www.jegs.com/i/Vibrant+Perfor...FViUfgodr7UAmg
Old April 23rd, 2015, 04:46 PM   #16
I dont think it's our cars are too sensitive, I think its the aftermarket cats aren't up to spec with the standards that Honda utilizes.
interestingly, I had a 91 civic that I stuck a cheapo aftermarket cat on and the light went off and was never an issue again as long as I had that car.
Old April 23rd, 2015, 05:20 PM   #17
accord325's Avatar
car-parts.com
OEM Used, good parts though.
Old April 27th, 2015, 09:51 AM   #18
Originally Posted by accord325 View Post
car-parts.com
no cats available. they dont even list them
Old April 27th, 2015, 10:07 AM   #19
its illegal to sell used cats. That's why car-parts.com doesn't list it.
Old April 27th, 2015, 10:53 AM   #20
I found a brand new OEM one for $462. no core charge. UPS Ground shipping $22.86.
not too bad. most places online want $600 or higher ($450+ plus $150 core charge) plus the shipping.
18160-RAA-A00 | Honda CONVERTER - Bernardi Parts
Old April 27th, 2015, 10:56 AM   #21
no it isn't. they just have to be re-certified before you can re-sell them.
Re Certified Catalytic Converter Accord 1457689 05 06 07 2 4L | eBay
