Idler Tensioner DIY Questions - Honda Accord Forum : V6 Performance Accord Forums
Like Tree1Likes
  • 1 Post By StevilKnievel
Old May 28th, 2015, 07:55 AM   #1
Calm like a bomb
StevilKnievel's Avatar
So, I have read over pretty much everything on the forums for 7G V6's idler tensioner pulley install and there is no common consensus here.
Some say the motor mount has to come out and the engine must be raised to clear the subframe. Some say you can remove the mounting bolts to the tensioner, leaving the pulleys bolts in, and just remove the PS reservoir and it can be worked out that way. Anybody out there done this that can give some input? Mine is on the verge of seizing and I'd like to get this done asap. I'd be happy to do a write-up with pictures for future reference to put this often asked DIY to bed once and for all.
Old May 28th, 2015, 09:38 AM   #2
accord325's Avatar
Pull the passenger front tire and work from there. Everything should be easily reached. Good idea to raise the car, just more room to work. I say this as my car basically sits on the ground
You may need to pull the lower timing cover, dont remember.
PS - The main bolt is long, so you will back out on to the frame. Use an open end wrench (not socket) or you could get your $hit pinned to the frame when backing the bolt out. Sucks trying to tighten the bolt back down when it gets pinned
Old May 28th, 2015, 06:07 PM   #3
07J30's Avatar
Please do a write up...or atleast report back with details on how you got it done...I'll need this at some point this year
Old May 29th, 2015, 09:42 AM   #4
Calm like a bomb
LOL. Will do.
Old May 30th, 2015, 11:53 AM   #5
Calm like a bomb
Just did this. Easy peasy. You do not need to move the engine if you are replacing the whole unit. I will have a diy w/pics soon.
EDIT: Here is the write-up I did http://www.v6performance.net/forums/...r-install.html
07J30 likes this.
Old November 18th, 2015, 12:44 PM   #6
Thanks for the writeup, very handy. My '03 is making a whining noise which I thought was the PS pump (which had been leaking), so I changed it out, and did the alternator while I was at it. The engine still whines so I'm assuming it's the idler, as there is no whine if I run the engine with the drive belt removed. Anyone else heard similar sounds due to an idler on it's way out?
Slabman is offline   Reply With Quote Quick reply to this message
