Ac problem - Honda Accord Forum : V6 Performance Accord Forums
Old June 11th, 2015, 12:45 PM   #1
Ac problem
Ok I have. 2007 accord v6 special edition last summer my ac was not blowing so cold so I recharged it it was a tad low and followed the directions which had a little arrow showing where it should be verses outside air temp.. Worked fine all summer now I try and use it and nothing but hot air.. Tried same remedy, however it shows the system is where it should be pressure wise..
I don't know where to start with AC issues
daver297 is offline   Reply With Quote Quick reply to this message
Old June 11th, 2015, 05:32 PM   #2
accord325's Avatar
Clutch relay, high or low pressure switch, bad compressor,etc. There are a lot of things it could be. Knock on wood, my Accord hasnt had an AC problem. However, my 91' Dakota does and it's from the Compressor clutch not kicking in. In my case, the relay is fine so it's either wiring running from the cabin AC unit to the relay box.....or it's a high or low pressure switch. It know this being I jumped the relay at the box
Old June 16th, 2015, 06:09 AM   #3
Is the clutch on the front of your compressor spinning with the ac on? Can you hear the compressor click and fans kick on when you turn it on?
TxRzrBk is offline   Reply With Quote Quick reply to this message
