Please help me to build my j30a4 - Honda Accord Forum : V6 Performance Accord Forums
Old June 24th, 2015, 05:22 AM   #1
Hello from Russia St. Peterburg
My name is Alexandr
I have Accord coupe 2003 j30a4 6mt. Iím having the engine repair now.
I use Honda Inspire j30a5 pistons for high compression
Now i want to now, what tuning should i use.
1. What about clutch (Aluminium or oem flywheel, may be Spec clutch)
2. What about cam shaft and crank shaft (j32a2 or TLS 2007? Should i use mdx crank or stay with oem?)
3. What about intake (TB from TL 3.7 it's good?)
4. What about rdx injectors?
5. And what about ecu.
In Russia nobody know about j series only k24. And nobody help me. Many thing from USA too expensive, because in 2014 we have 1$ to 30 ruble and now we have 1$ to 60 rubles. But salary is the same as 2014.
Thank you for answer and sorry for my English =)
sasa is offline   Reply With Quote Quick reply to this message
Old June 27th, 2015, 05:31 PM   #2
Nobody?
Old June 27th, 2015, 05:45 PM   #3
we don't build j30 here in the states. we just swap to the larger j32a3 motor.
Old June 27th, 2015, 10:25 PM   #4
The Jester
He's actually about right. If you want to build the j30 it will end up costing more unless many crash the TL-S or MDX out there.
Cams, TLS or MDX. Intake, manifold from J37 and throttle body from J37(MDX or big TLS)
Others will need to help for clutch flywheel packages and crankshaft suggestions.
Porting will be best easiest power. As always. Second only to J32a3 swap.
Old June 29th, 2015, 05:28 AM   #5
I Understand, but we have'nt j32a3 =)
I want to build something from j30.
Old June 29th, 2015, 05:32 AM   #6
Thank you for answer.
Yes, j32 it's right way, but i can't find it in Russia.
It's usa engine, i can't find accord coupe with 6mt for a long time. I drove 2000 miles and bought.
Ok, we have MDX cams, from which model? First or secon gen.?
Old June 29th, 2015, 05:35 AM   #7
And what about crank from MDX. It work?
Old June 29th, 2015, 02:33 PM   #8
J35 6Spd
The J35 crank should work.. you may need some other internals as well. Search the forums for J33 (J30 with J35 internals = 3.3L)
Old June 30th, 2015, 08:08 AM   #9
accord325's Avatar
03-06 MDX. You need the crank, rods and bearings.
Old July 1st, 2015, 12:02 AM   #10
Ok, what about crank from ZDX, MDX 3.7
Old July 1st, 2015, 12:03 AM   #11
I can buy j35 crank and rods. Its only 150$.
Old July 1st, 2015, 08:58 AM   #12
accord325's Avatar
3.7 MDX should work. Again, you need the rods
Point A to B
NA.... Till I Spray
Old July 1st, 2015, 03:19 PM   #13
What about ZDX. The same as MDX.
I can buy ZDX crank and MDX rods.
What better 3.7 or 3.5 crank?
Old July 2nd, 2015, 03:50 AM   #14
And what negative things if i do j34.
Old July 2nd, 2015, 03:53 AM   #15
I want use Honda Inspire pistons (high cr)
Acura RL cams
And ZDX crank and MDX rods.
What about hp of this mode? with cai and custom exhaust
Old July 2nd, 2015, 07:29 AM   #16
accord325's Avatar
Never heard anyone running the ZDX crank. If your getting the MDX rods, why not the crank too???
Old July 2nd, 2015, 05:04 PM   #17
In Russia it's a big problem
I finded only zdx crank and mdx rods. But article number is the same
Old July 2nd, 2015, 06:31 PM   #18
If parts are that hard to find...us US guys could possibly ship them to you.
Are the 4 bangeres popular there? You found always find aftermarket rods/pistons...keep the displacement at 3 liter, get cams springs and valve work and shoot for an 8k redline.
Old July 2nd, 2015, 07:42 PM   #19
The Jester
I considered this, but contradictory statement above. Local economy is different and probably favors junkyard parts. Shipping is also painful.
ZDX MDX might work, nobody holds onto crashed zdx's here though so it likely just hasn't been tried. Any part# geniuses?
Personally with RLS cams, an upgraded stroke, a higher compression, with higher longer lift and faster spinning cams, I wouldn't consider a bad option for a junkyard sourced upgrade car.
Old July 4th, 2015, 07:02 AM   #20
So, it's a bad config?
New Honda Inspire pistons
New springs
Acura RL cams
MDX crank and rods.
Or should I stay 3.0 just change my pistons springs and steam seals
Old July 4th, 2015, 07:12 AM   #21
Bangeres it's mean 4 cylinder?
Yes, very popular k20 and k24 engine. We build k24 with k20 heads.
But most people use jakson racing supercharager.
Old July 4th, 2015, 07:15 AM   #22
I found zdx crank and seller said that its honda's service mistake. They change good crank to good crank. May be its a lie
Mdx crank about 500$ rods 200$ cams 500$
Old July 14th, 2015, 01:14 AM   #23
j32a2 and j32a3 block are the same?
