key wont enter the keyhole - Honda Accord Forum : V6 Performance Accord Forums
Old June 25th, 2015, 11:12 AM   #1
so my key will not go into the door keyhole but starts the engine completely normal. i have no idea what it can be, i figure if the key is bad it wouldnt start the ignition so it has to be within the door panel
asoberon428 is offline   Reply With Quote Quick reply to this message
Old June 25th, 2015, 11:47 AM   #2
J35 6Spd
must be something stuck in the keyhole, or the key cylinder is broken
Old June 25th, 2015, 01:25 PM   #3
Bobby Lane Racing
nighthawk04v6's Avatar
lube it up she said
Old June 25th, 2015, 03:01 PM   #4
Calm like a bomb
StevilKnievel's Avatar
There is a flap that covers the keyway inside the cylinder and that flap is held closed by a tiny spring with two little tabs sticking out of each end. My guess is a tab has broken and wedged itself between the cap and cylinder. Get something approximately the same size and shape as the key and keep working it in there. Use some force but be careful not to snap the whateverthehell you are using.
