rod bearings for j37 crankshaft - Honda Accord Forum : V6 Performance Accord Forums
Like Tree1Likes
  • 1 Post By CBUS-AV6MT
Old May 13th, 2016, 01:18 AM   #1
Hi. Can you help me, what rod bearings should i buy. Honda dealer cant help me
Acura ZDX crankshaft
sasa is offline   Reply With Quote Quick reply to this message
Old May 13th, 2016, 05:39 AM   #2
M90SC Boosting 13PSI
NVA-AV6's Avatar
You also need the codes on the rods, you only are giving 1/2 the puzzle....
How's that hope and change working for you???
Old May 13th, 2016, 01:15 PM   #3
I have 5 ZDX rods and numbers:
Big 2
Then 75011(the same on each rods)
03316 (different on each rods)
And I need one rod, can I buy from MDX or I should buy definite rod
Old May 13th, 2016, 01:16 PM   #4
And can you say me, spec light flywheel it's good or not with oem clutch
Old May 13th, 2016, 05:00 PM   #5
07J30's Avatar
Just download any honda v6 shop manual and go to block assembly. Read.
Old May 14th, 2016, 02:14 AM   #6
This is Acura ZDX crankshaft
Old May 14th, 2016, 05:33 PM   #7
I think he's referring to the process of determining which bearings you need. The v6 guide teaches you have to read and interpret the markings on all of the parts to pick the correct bearings.
07J30 likes this.
Old May 20th, 2016, 12:48 AM   #8
So, if i have 2 on rod and the first on crankshaft its C, i need yellow/green?
