Anybody with Koni/Pro Kit Combo - Honda Accord Forum : V6 Performance Accord Forums
Like Tree1Likes
  • 1 Post By chivic
Old March 5th, 2012, 09:39 PM   #1
KaotikPlaya's Avatar
Seeing if anybody has the koni sports and eibach pro kit springs. I have the pro kit, and need new shocks. Wondering how the ride is and if it evened the wheel gap with the perches
KaotikPlaya is offline   Reply With Quote Quick reply to this message
Old March 6th, 2012, 08:38 AM   #2
How about anybody using koni/ ground controls?
Old March 7th, 2012, 08:20 PM   #3
I have a buddy with eibach prokit and the koni yellows. the ride is really stiff and there is no body roll. i like it i think its a nice set up and sits very clean. the ground controls would be a good option too if you want to go really low. I beleive if im not mistaken the koni yellow lower your car a little more. Im not too sure. my friends car was a bit lower after adding the koni yellow. he installed the eibach pro-kit on the oem shocks prior to the koni yellows. HUGE difference in the ride. he has the i4 cm7 accord
fffuhq is offline   Reply With Quote Quick reply to this message
Old March 8th, 2012, 07:57 AM   #4
I had this setup on my old 6th gen Accord. It's not THAT stiff. The Koni yellows are firmness adjustable so you can make it softer if you'd like. It doesn't even out the ride, that's up to the springs to do that job. You will like it.
Team Racing Direction
Old March 8th, 2012, 11:53 AM   #5
i wish they made the kyb agx for the 7th gen accord though.
Old March 8th, 2012, 04:27 PM   #6
Furlow's Avatar
I have the Eibach Pro Kit and Koni Yellows. The ride is very nice. Replace the bushings and bump stops when you do the shocks, the stock ones suck.
The Koni's have adjustable "perches" in the front and rear so you can play with them to dial in the ride height. I was able to get the front and rear identical.
Furlow is offline   Reply With Quote Quick reply to this message
Old March 8th, 2012, 04:32 PM   #7
What perches did you use for front and rear? Where did you get the bushings and bump stop?
Old March 9th, 2012, 12:53 AM   #8
RCChin31's Avatar
I run Koni/ GC and im happy with what i got. You can go pretty low with them. I killed all my wheel gap and then some and i still have more thread left to lower if id like. The ride is comfortable. My accord is my DD and in addition to that im in san francisco a lot where the roads are crap so its nice to have the ride comfort along with the drop that you want.
RCChin31 is offline   Reply With Quote Quick reply to this message
Old March 9th, 2012, 04:09 AM   #9
Furlow's Avatar
I'm on the middle perch in front, upper perch in rear. I tried the lowest for both but it was just too low for my taste. The guy who lowered my car had a hook up on energy suspension bushings and bump stops, so I bought them from him.
Old March 9th, 2012, 10:31 AM   #10
Do you have a pic of your car? Those are the perches I was thinking.
Old March 9th, 2012, 12:51 PM   #11
Furlow's Avatar
Here are some of my set up now:
With 19's:
It works well with either size wheel/tire. I personally think that 18's are best for this type of drop. The tire height on 19's requires a lower drop for the best esthetics. A good general rule is that the tire height and wheel well gap should be about the same.
Old March 9th, 2012, 03:10 PM   #12
Awesome,thanks, those are the perches i'm going to start with. I can't go too low around here in utah with the lip kit. Did you have the pro kits before the koni's on stock shocks?
Old March 10th, 2012, 07:55 PM   #13
Furlow's Avatar
I did. The ride was okay, but kind of rough. Not very responsive and somewhat bouncy. The front wasn't quite low enough either. When I heard about the Koni Yellows I was sold. Best $400 you can spend on our car. It really was a different car after that.
I play with the adjustable damper settings, that's fun too. It can be anywhere from a stock feel all the way to a race set up. Easy to do as well.
Old March 15th, 2012, 05:53 PM   #14
How much wheel gap do you have on front/rear? Does it seem like rear looks higher than front on those perches? That's how i set mine up and the rear seems like it's higher but the fenders are same height from ground. Before the front was noticeably higher. It rides and handles great though
Old March 16th, 2012, 10:19 PM   #15
Furlow's Avatar
It's about two fingers of gap, I've never measured it. Just eye balling, it looks dead even to me. You could try going up one more perch on the front if you think it looks too low
Old April 5th, 2012, 01:57 PM   #16
Good discussion, I read with great interest!
Will be installing koni yellows on my i4, 4 door. I wanted the 2 finger gap and was originally sold on h&r OE line of springs as it had a .75" drop up front. With the ability to adjust perches, I will go with either h&r sport or eibach prokits instead Awesome pics, gave me a good idea of how my black mica would look like.
Is the ability to adjust the perches after install hard to get to? I will most likely mimic your middle setting up front and upper in the rears.
Good tip on bump stops and bushings!
Shadytype likes this.
chivic is offline   Reply With Quote Quick reply to this message
Old April 6th, 2012, 10:40 AM   #17
im on koni sportline
Old April 6th, 2012, 10:41 AM   #18
can't adjust perches after install
Old April 6th, 2012, 11:16 AM   #19
I actually adjusted mine on the car. I just put the spring compressor at top of spring and bottom of perch.Compressed enough to get it above perch, dropped perch, took off compressor. It only took a few minutes, just make sure the back of the perch is above the clip.
