Largest Tire on HFP 17s? - Honda Accord Forum : V6 Performance Accord Forums
Old April 20th, 2012, 11:49 AM   #1
Im looking into possibly buying a set of drag radials for my HFP 5 spoke 17s. Trying to figure out what would be a good size.
Wondering it 235/45R17 would fit, currently have 215/50R17s...
04 Accord 6-6 Coupe
13s no matter what hp I have
Just an All Motor J30...
Zach @ YCU Dyno Tuning
Old April 20th, 2012, 04:21 PM   #2
anyone ?
Old April 20th, 2012, 06:55 PM   #3
What is your rim width? If it's 7" then 235/45-17 is beyond most manufacturer's recommendations for a 7" rim.
06 coupe silver 6 speed
ypsibird is offline   Reply With Quote Quick reply to this message
Old April 21st, 2012, 07:13 PM   #4
^Yeah, you'll have to look up the manufacturer's rim width range for whatever specific tire you want to run.
If you only care about straight-line performance, you can select a tire that specifies 7" towards the bottom of the range. This will put the largest tire patch on the road at the expense of lateral traction.
I don't know how you want to select the tire diameter, though. Are you running out 4th gear in the 1/4 mile? You can adjust your overall tire diameter to put you in the powerband in your final 1/4 mile gear (smaller diameter) or limit your wheelspin on launch (larger diameter)...whatever you choose to do.
Old April 22nd, 2012, 10:01 PM   #5
Well im looking for some new tires soon. So why not Drag radials. wider is better right... and I dnt race around curves. So maybe I will just move up to a 225.
