tein S tech ?? - Honda Accord Forum : V6 Performance Accord Forums
Old April 22nd, 2012, 07:27 AM   #1
tein S tech ??
so they sell them for both the V6 and 4 banger they are not both the same correct ? but the ones for the 4cy will fit the V6 and just sag down a little becasue of the weight ?
05coupedriver is offline   Reply With Quote Quick reply to this message
Old April 22nd, 2012, 07:31 AM   #2
-Brian
NexsoN's Avatar
Get the right ones for your car, different spring rates because the weight of the v6 and its engine.
Old April 22nd, 2012, 09:34 AM   #3
NexsoN is right.. not only will it sag if you get the wrong springs, but the shocks will bottom out and blow due to the low spring rates. Get the right one... btw, Tein S-techs will sag quite a bit over time so be sure you want that much of a drop.
Fanitron is offline   Reply With Quote Quick reply to this message
Old April 22nd, 2012, 10:22 AM   #4
ya no I am going to get the right ones for my car I was just speaking to a seller and he was telling me that their is just one set of Tein S tech springs for both 4-6 7th gen accords and i was saying that i was not quite sure becasue I was looking around for a set and seen the two differents sets
Old April 22nd, 2012, 10:41 AM   #5
If your dealer is saying that, I'd go somewhere else...lol j/k but you should prob show him this
HONDA ACCORD
CM5 03-07 STECH 4cyl 4dr P/N:SKA50-AUB00
$290.00
Spring Rate: F: 6kgf/mm or 336lbs/in R: 4kgf/mm or 224lbs/in
Drop: F: -1.8in R: -1.3in
HONDA ACCORD
CM6 03-07 STECH 6cyl 4dr P/N:SKA52-AUB00
$265.00
Spring Rate: F: 5.5kgf/mm or 308lbs/in R: 3.5kgf/mm or 196lbs/in
Drop: F: -2in R: -1.2in
Old April 22nd, 2012, 11:32 AM   #6
I find it odd the 4 cyl uses stiffer rates than the heavier v6. Good info though.
dandaman15 is offline   Reply With Quote Quick reply to this message
Old April 22nd, 2012, 12:33 PM   #7
Yea dude. I never quite understood the logic behind this but my guess is it was to achieve the desired drop rather than provide proper ride/performance. Which is the main reason I personally went with Eibach Sportlines instead
Old April 22nd, 2012, 04:23 PM   #8
naughtyaccord's Avatar
Why does the v6 have such a low spring rate what's a good spring to get for the 07 v6 6
naughtyaccord is offline   Reply With Quote Quick reply to this message
Old April 22nd, 2012, 06:45 PM   #9
You're gonna hear lots of diff opinions on this (cause it's really an opinion)... depending on what type of height/feel you're looking for but here are some options.
Tein:
Htech - F: 1.4" R: 0.7"
Stech (as stated above)
Eibach:
Pro-kit - F: 1.3" R: 1.2" (not a good look though.. front is too high in comparison to back)
Sportline - F: 1.9" R: 1.4" (the rear will almost tuck, front has about 1 1/2 finger gap)
H&R:
OE Spec - F: .75" R: .5"
Sport Spec - F: 1.5" R: 1.3"
Race Spec - F: 2" R: 1.7"
There are more.. but those seem to be the most popular/recommended. Hope this helps!
