ran into a little problem installing springs - Honda Accord Forum : V6 Performance Accord Forums
Old May 1st, 2012, 11:21 AM   #1
so i am installing S tech springs and i get to the last front one to find out the the bolt at the bottom on the fork is like frozen and won't come lose has anyone had this happen to them?
05coupedriver is offline   Reply With Quote Quick reply to this message
Old May 1st, 2012, 11:55 AM   #2
I've had that happen to me but on the rear.
You might have luck using a impact gun on that instead.
Wai_pang2 is offline   Reply With Quote Quick reply to this message
Old May 1st, 2012, 01:17 PM   #3
ya that actually what i am using the impact gun with a compressor and still won't even budge
Old May 1st, 2012, 01:28 PM   #4
try sparying some PB Blaster on it. If that doesn't work heat it and then impact it out
Old May 1st, 2012, 01:57 PM   #5
k24
FRAUDULENT SELLER
k24's Avatar
Send a message via MSN to k24 Send a message via Yahoo to k24
+1 ken knows whats up
k24 is offline   Reply With Quote Quick reply to this message
Old May 1st, 2012, 03:15 PM   #6
put PB blaster and heated it and still didn't come out lol
Old May 1st, 2012, 03:33 PM   #7
Randomhero's Avatar
Had the same problem when changing the axle on my old Neon R/T. Clevis bolt wouldnt budge for heat or soaking. I ended up sawzalling that b*tch off, and replacing it with a new one
Current:
08' BMW E90 335i 6MT ~420whp
Old May 1st, 2012, 03:45 PM   #8
ya i am thinking if not i am going to drill it out and buy a new one
Old May 1st, 2012, 04:43 PM   #9
JonnyBravo's Avatar
Same thing happened to me in the front , I ended up cutting the bolt off on both ends, and ended u replacing the bushing . PITA !!
JonnyBravo is offline   Reply With Quote Quick reply to this message
