clunking noise in front struts - Honda Accord Forum : V6 Performance Accord Forums
Old May 2nd, 2012, 03:57 PM   #1
so i installed s tech springs on my 7th gen coupe and now i am hearing clunking noise bad in the both fronts everything is tight the noise is coming from the top of the strut anyone help out with what the noise could be ??
05coupedriver is offline   Reply With Quote Quick reply to this message
Old May 2nd, 2012, 04:42 PM   #2
Quicksilver
davesv6's Avatar
is it when you hit bumps?? are the struts old???
davesv6 is offline   Reply With Quote Quick reply to this message
Old May 2nd, 2012, 05:14 PM   #3
Yes when I hit bumps its an 05 with 60k on them
Old May 2nd, 2012, 07:51 PM   #4
anyone else can help me ?
Old May 2nd, 2012, 09:14 PM   #5
Quicksilver
davesv6's Avatar
i think you need new struts to be honest... or ball joints...
Old May 2nd, 2012, 09:26 PM   #6
Ya I was thinking the ball joints as well also I didn't cut the bump stops could that be somthing making the noise ?
Old May 2nd, 2012, 10:57 PM   #7
Quicksilver
davesv6's Avatar
i didnt cut mine either, but i did have the same noise your talking about at about 60k and it ended up being a blown strut.
Old May 2nd, 2012, 11:25 PM   #8
JDM UC1
toinkee69's Avatar
blown strut, bottoming out or check the nut on the top hat. if that thing is loose it makes a clunk noise to.
Old May 3rd, 2012, 12:01 AM   #9
Jesse
Jesnuts's Avatar
probably blown
Jesnuts is offline   Reply With Quote Quick reply to this message
Old May 3rd, 2012, 08:09 AM   #10
Quicksilver
davesv6's Avatar
he said everything is tight....i still think its a blown strut
Old May 3rd, 2012, 09:33 AM   #11
yes everything is tight. but they would both go right away with a set of springs installed?
Old May 3rd, 2012, 10:41 AM   #12
Quicksilver
davesv6's Avatar
no, but if the struts were already getting worn out then the stress they are under with being lowered could cause them to finally just fail. have you looked at your ball joints yet though?
Old May 3rd, 2012, 12:03 PM   #13
ya none of them are riped or anything did the old lift the car up and try to wiggle the tire trick and the tire didnt move
Old May 3rd, 2012, 12:39 PM   #14
ruin0ne's Avatar
Mine does that noise when I go over bumps too! I checked and I have a bad ball joint..
ruin0ne is offline   Reply With Quote Quick reply to this message
Old May 3rd, 2012, 01:02 PM   #15
Ya I am droping it offf at the shop and going to have them take a look at it
Old May 3rd, 2012, 04:15 PM   #16
ruin0ne's Avatar
Let us know! Lol
Old May 5th, 2012, 09:31 AM   #17
so got the car back last night and like you all stated on here it was the front two struts
Old May 5th, 2012, 09:36 AM   #18
Humble
7gv6coupe's Avatar
I have that noise also when I hit bumps. More from my driver side strut but I changed that one about 3 months ago!
7gv6coupe is offline   Reply With Quote Quick reply to this message
Old May 5th, 2012, 10:59 AM   #19
Quicksilver
davesv6's Avatar
told ya so haha just playing man!! im just glad you fixed the problem. did you put the KYB struts?
Old May 9th, 2012, 01:35 PM   #20
Humble
7gv6coupe's Avatar
Put mines on the lift today during class, and my clunking noise is coming from my tie rod.
