Tires Recommendation For HFP 19's - Honda Accord Forum : V6 Performance Accord Forums
Old May 10th, 2012, 03:54 PM   #1
i have a accord 2003 which is drop, i bought the 350z rims and i had to change them better they where messing with the fender plastic inside and the tires where 225/50. i know that for the hfp 19 they recommend 245/40 i would like to know if thats good or if im goin need to get my fender roll and get camber kit also? or maybe get 225/40 or 235/40?
andy809 is offline   Reply With Quote Quick reply to this message
Old May 10th, 2012, 04:07 PM   #2
Duck617's Avatar
which 350z wheels did you get
Duck617 is offline   Reply With Quote Quick reply to this message
Old May 10th, 2012, 06:09 PM   #3
The 2003-2007 they where 17s
Old May 10th, 2012, 06:14 PM   #4
get 215 50 17 or 225 50 17 maybe even 235 45 17
Old May 10th, 2012, 07:12 PM   #5
I sold the 350z cause i had problems with the tires now i bought the hfp 19s i just need to know wat tires to get so they wont make contact wit the fender plastic.
Old May 10th, 2012, 07:22 PM   #6
oo sorry. I miss read.. Used this chart
Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
Old May 11th, 2012, 12:26 AM   #7
Maverick_Supersonic
DjKing07AV6's Avatar
iirc, those hfp 19s are only 7.5 or 8 inches wide. so you could use 225/35 or 225/40 and be just fine.
DjKing07AV6 is offline   Reply With Quote Quick reply to this message
Old May 11th, 2012, 11:14 AM   #8
M![email protected] \_(ツ)_/
HEcreated487's Avatar
HFP 19's are 19x8 et55. Your tire options are:
215/35
225/35
225/40
235/35
245/35
245/40
To not throw off the speedodometer by more thatn 3% (i.e. OEM rolling diameter is approximately 25.4"), check the rolling diameter for each tire size. I believe the only sizes that are beyond the 3% rolling diameter change are the 215/35 and 245/40. You should also take into account side wall thickness and tire width, whatever is your preference. Thicker side wall and larger tire width should provide more protection of your wheels. GL!
Old May 12th, 2012, 12:09 AM   #9
i think im just goin to end up with 225/40 thank you guys.....
Old June 11th, 2012, 03:40 PM   #10
Hate to bring up an old thread but I'm have a similar question to andy.
I want to install the 19" HFP PDS-10 wheels on my '06 6MT Coupe. I have the HFP suspension installed. I'm debating between 225/40/19 and 235/35/19. Tire calc Tire size calculator has 235/35/19 being the proper rolling diameter with 0 variance but I'm concerned about running 35 series tires here in Pittsburgh. Potholes are pretty bad here so I was thinking going with 225/40/19 to offer some additional side wall protection. Thoughts???
passmaster16 is offline   Reply With Quote Quick reply to this message
