Sway Bar's and how they work. - Honda Accord Forum : V6 Performance Accord Forums
Like Tree1Likes
  • 1 Post By NvrDwn
Old June 28th, 2012, 05:41 AM   #1
Sleeper
NvrDwn's Avatar
Thought I'd clear this up a little for people.
I find it odd that with Accords the front bar is bigger than the rear bar, and yet people still talk about how the rear can kick out with the front being 5.5mm thicker than the rear TL-S bar. That leads me to think the front bar must be significantly softer compared to the rear TL-S bar, or people don't know how to drive a FWD car properly..
I know a bit about suspension and how it works on FWD and RWD cars.
Let me explain.
A larger rear sway bar allows a FWD car to have more grip up front, and a larger front sway bar allows more grip in the rear.
Here’s an article with pictures to back me up:
How sway bars work
Ok, now for clarification. Will a much bigger rear bar give us oversteer? Yes. Why? Simply look at the picture in the website above. Will a bigger rear bar (but not by much) still give us oversteer? Well, maybe some, or a feeling of it, but it will be mostly understeer or a neutral feel. It should feel about neutral if the front is 3mm or less thinner. On my old Focus 22mm front bar, 25mm rear bar, I never had oversteer except once, on a VERY tight corner. It's one that starts off wide and gets smaller as the turn progresses. 30mph at the beginning and I had to let off the gas and THAT along with wet pavement allowed oversteer, but not enough to lose control. I believe the reason why people are talking about oversteer with the stock front and rear TL-S sway is because there is a lack of driver experience. As it is now it's nearly impossible to get oversteer with the stock sway bars no matter what you do, the only exception being to pull the e-break in mid-corner. So when someone gets a much bigger (6mm is much bigger) rear sway bar the car goes from being impossible to oversteer even if letting off the gas in mid-corner, to a car that can now oversteer under the right circumstances.
Also for additional back-up go to tirerack and look up the sway bars for a mustang, and then some for an 03 ford focus.
Mustang has a bigger front than rear bar and a Focus has a bigger rear than front bar.
Of course cars don't come like this because they want you to have understeer as that is much more controllable.
Hope this makes sense to people and is able to help those having oversteer problems!
blk_on_blk likes this.
