New Mod, odd size.. - Honda Accord Forum : V6 Performance Accord Forums
Like Tree1Likes
  • 1 Post By funkbro2
Old September 8th, 2012, 10:59 PM   #1
Blackaccord07's Avatar
New Mod, odd size..
Ok so I'm currently running 18x9.75 with a 20 offset all around and im planning on going wider, now my main concern is the front, my fenders are a little pulled out and I'm running front Megan Racing upper control arms for camber, my car don't rub at all and it sits rite on top of the tire.. My question is, would 18x10.5 with a 22 offset will fit in the front? Will it hit the bar that connects to the disk?? Not allowing the wheel to go all the way in?? Please tell me if you know any1 whos done this mod Thank you in advanced
Official Member of the
_____________________________
Ijole bueyyyy, es un accord!! Taquitos y papas please.
Blackaccord07 is offline   Reply With Quote Quick reply to this message
Old September 9th, 2012, 06:58 PM   #2
O_o
iakona08 likes this.
Old September 9th, 2012, 07:05 PM   #3
Lmao ^^^ crazy ideas I know
Old September 9th, 2012, 07:19 PM   #4
M![email protected] \_(ツ)_/
HEcreated487's Avatar
Intriguing title... Not sure I could contribute to your questions, but would love to see you pull it off GL bro!
Old September 10th, 2012, 04:02 PM   #5
NC Fresh
yarg. i'm not sure too many people would know the answer to this, but you may start to run into inside clearance issues. depending on how low you are, it allllll depends how low you are.
iakona08 is offline   Reply With Quote Quick reply to this message
Old September 10th, 2012, 05:13 PM   #6
JDM UC1
toinkee69's Avatar
red = sarcastic. this is a trick, right? lol.
Old September 10th, 2012, 06:06 PM   #7
Did a little bit of calcs. New wheel setup will extend approximately ~12mm closer to your inner suspension components and have approxmately ~8mm more "poke" towards the outer fender.
Just measure your inner clearances and see if it'll fit
Old September 10th, 2012, 06:57 PM   #8
-Gene
phunctional's Avatar
Naw he just does it to try and stand out I'm guessing
phunctional is offline   Reply With Quote Quick reply to this message
Old September 10th, 2012, 10:50 PM   #9
JDM UC1
toinkee69's Avatar
Booooo...
Old September 11th, 2012, 04:28 PM   #10
Hecreated, thank you for the calcs, im soon the measurements ritenow, I'm pretty sure it will fit..
Phunctional: I do it just because I like been different lol
Iakona: thanks man, I'll be careful with the drop..
Toinkee: There's nothing sarcastic about this, it's a serious question, I'm really doing it..
