Is 1.9% size difference too much? - Honda Accord Forum : V6 Performance Accord Forums
Old October 21st, 2012, 09:46 PM   #1
Ric
Hello,
My accord v6 came with 215/50/17 I'm planning to with 225/45/17 so will be a 1.9 decrease in size is this too much or is ok?
Regards,
Ric
Ric is offline   Reply With Quote Quick reply to this message
Old October 21st, 2012, 09:52 PM   #2
I wouldn't put 225's on that width rim, but a 2% decrease is OK
Many people run 225/40 R18 which is 2% small if you have the 4 cylinder stock
225 width will be wide for the stock wheels, but its doable, will be more comfortable but not as good handling
Old October 21st, 2012, 10:15 PM   #3
Ric
Thank for your replay the wheel is 7.5 inch wide, for reference 2011 accord sedan comes with 225 tires and the stock wheel is 7.5 inch too.
Old October 21st, 2012, 10:57 PM   #4
Randomhero's Avatar
225/45-17 on a 17x7in wide rims is fine, just look on tirerack. I had them on my car, helped a bit. Bumps sucked though lol
Current:
08' BMW E90 335i 6MT ~420whp
Old October 22nd, 2012, 07:42 AM   #5
Sonnick's Avatar
You will be fine with those tires. I ran 225/45s on my stock 6.5" wheels and probably will do it again come spring
Old October 22nd, 2012, 07:42 AM   #6
I would go with 235/45-17 which only results in a -.05% difference. The tire charts I've seen indicate that a 235 is ok on a 7.5 rim and you get the advantage of getting a little more rubber on the road and very little speedometer error. I've got 235/45-17's on my TL wheels which are a little wider at 8" and they seem fine to me.
06 coupe silver 6 speed
ypsibird is offline   Reply With Quote Quick reply to this message
Old October 22nd, 2012, 04:26 PM   #7
yal
Don't do it if you live in NY boroughs lol. The ride is harsher on bumps and potholes. Had 225/45/17 on Civic Si rims 7" wide and felt it. 225/50/17 feels much better
yal is offline   Reply With Quote Quick reply to this message
Old October 22nd, 2012, 10:01 PM   #8
Ric
