LCA lower control arm problem - Honda Accord Forum : V6 Performance Accord Forums
Old November 6th, 2012, 11:17 AM   #1
nismoasfuh's Avatar
Okay, I have an 03 6-6. And one main Thing that's wrong with my car is that upon acceleration, my car will vibrate and shake. And if I brake from high speeds or even sometimes in lower speeds, my car will shake violently and sometimes ill even feel it in my steering wheel. I always assumed its my brake rotors with a combination of one of my wheels being very slightly bent. But recently I've been noticing more and more that The front of my car makes subtle noise when going over bumps as if something is loose. And backing out of my driveway where there's a little bump where my driveway meets the street, I always hear/feel it. So now I'm thinking an LCA problem either a balljoint or bushing? I'd really like to pin point the problem, I'm pretty sure my bent wheel is causing soooome problem, and my brakes definitely need something too, but I can't shake the feeling it's something else. My car was originally bought and drove around New York city for the first 5 years of its life, assuming that it's true that NYC has some really bad roads (just like Miami... -.-) I'm thinking shocks are messed up too cause I feel alot more of a "floaty" feel from the front that the rear. I just would like some input as to what people think. I'm due for a timing belt change soon, but I'd really not like to have a popped tire/broken brake rotor/ or LCA fall of on me while driving haha. Most likely will be taking it to the mechanic but I'll update this thread until I solve my accords shake.
Old November 6th, 2012, 12:44 PM   #2
Bobby Lane Racing
nighthawk04v6's Avatar
front LCA bushing tear will cause a thud up and down drive ways and over bumps.
Vibration under braking, is rotors warped.
Vibration during acceleration is wheel balance, or drive shaft axle.
Old November 6th, 2012, 04:31 PM   #3
nismoasfuh's Avatar
Thanks!
Old November 25th, 2012, 12:19 PM   #4
Bursaliozer's Avatar
I have the same problem, havent been able to pin point it. My Ball joint snapped and broke my axle and messed up my fender, always thought it was that but started happening again after getting all that fixed. I will check the LCA bushing on mine as well, thanks.
Bursaliozer is offline   Reply With Quote Quick reply to this message
Old November 25th, 2012, 02:10 PM   #5
^ wtf is up with the multi post?
Old November 25th, 2012, 10:41 PM   #6
Picture Perfect
Milan's Avatar
Looks like a glitch but yeah, messed up lol.
Old December 4th, 2012, 04:48 PM   #7
VTEC PWNES ALL
2muchbass's Avatar
hahaha thought i was in a time warp
2muchbass is offline   Reply With Quote Quick reply to this message
Old December 12th, 2012, 11:52 AM   #8
Check the compliance bushings in the front lca's. It is a common problem on the tsx, tl, and accord. It was a new design implemented by honda in 2003-2004.
Here is what heeltoe posted as reason for the compliance bushings:
Originally Posted by mrheeltoe
The compliance bushings in later model Acura and Honda vehicles were part of an innovative design to handle suspension movement. Despite being unconventional, the system worked well at softening road inputs while effectively keeping the control arm attached to the car. Unfortunately the compliance bushings wear prematurely and crack, causing sloppy handling and excess vibration. The issue plagues TSX and TL divers alike, with many TL drivers reporting failures within 60,000 miles.
Link
http://www.heeltoeauto.com/tech-arti...gs-by-pci.html
Heeltoe does offer spherical bushing replacements, but the set is pricey at $300.
Fastline Performance Compliance Bearings by PCI, 04-08 Acura TSX / TL TL-S - HeelToe Automotive
You can keep re-using stock bushings but expect to change them every few years.
brian6speed is offline   Reply With Quote Quick reply to this message
Old December 12th, 2012, 01:51 PM   #9
Picture Perfect
Milan's Avatar
Wow, these look pretty and interesting, pretty interesting lol...anyone have these installed? I'd imagine the ride quality would suffer a bit.
Old December 12th, 2012, 02:40 PM   #10
Some people on acurazine have them installed. Heeltoe installed them on their project tsx.
On my 03 cl, my lca's don't have compliance bushings, but heeltoe let me just purchase the other 2 bushings to try out.
Old December 12th, 2012, 04:23 PM   #11
Picture Perfect
Milan's Avatar
Hmmm...I kind of want these after reading up on AZine. I don't think my bushings are torn yet...will have to keep an eye out.
First impressions in post #23
Fastline/PCI Compliance Bushings Pre-sale/Launch - AcuraZine Community
Installed on the Heeltoe TSX
FLP Compliance Bearings Install and Impressions - AcuraZine Community
The article in the above thread
HTSpec TSX gets new Fastline Performance Compliance Bearings by PCI - HeelToe Automotive
Old June 25th, 2015, 08:10 PM   #12
bump from the dead. I bought some moog control arms and lower ball joints. Lets see how the install goes... Ebay has a discount 20 bucks off 100. So might be worth it if you guys need auto parts.
Old June 25th, 2015, 08:27 PM   #13
Sorry haven't read the thread. Is this for the front or rear LCA?
Old June 25th, 2015, 08:47 PM   #14
Front LCA. Its the wishbone looking thingy. FB you
Old June 26th, 2015, 05:13 AM   #15
Ilovemyvtx's Avatar
I bought the Super Pro bushings for my car before I dumped it. They felt sweeeeet.
Ilovemyvtx is offline   Reply With Quote Quick reply to this message
