Saggy bottom blues on my Accord EX V6 - Honda Accord Forum : V6 Performance Accord Forums
Old January 31st, 2013, 12:44 PM   #1
The Syndicate Martyr
Dynamatt's Avatar
Send a message via AIM to Dynamatt
Hey guys, I haven't posted on the site in a long time but i have an '06 Accord EX coupe with the HFP springs and like many before me, it has the saggy bottom syndrome. It doesn't help that i have a hitch installed and more often that not have my bike rack attached to the back. What i'm here for is i am looking into new spring, strut combos but i don't want to sacrifice too much of my current ride characteristics as i commute a little over 300 miles weekly. And advice on what you guys are currently running, or maybe some of you have swapped from the HFP kit and have some ride comparisons. Any help is greatly appreciated
Dynamatt is offline   Reply With Quote Quick reply to this message
Old January 31st, 2013, 01:30 PM   #2
Old Member
Du3ce's Avatar
Try the tein h tech
Old January 31st, 2013, 04:21 PM   #3
M![email protected] \_(ツ)_/
HEcreated487's Avatar
Get a pair of Koni yellows for the front, swap in the HFP springs and adjust the height of the lower spring perch. Done.
Old January 31st, 2013, 07:11 PM   #4
Dynamatt's Avatar
That option crossed my mind after I posted. Anybody have some good miles in in the Koni yellows? I'd swap all 4 as I still am on factory shocks/ struts.
Old February 1st, 2013, 11:45 AM   #5
The name is Z
CrackerTeg's Avatar
See my response to your thread on ECM.
Old February 16th, 2013, 01:27 PM   #6
Saggy bottom? I have HFP suspension and don't have a "saggy bottom"
Did you somehow get a hold of a set of HFP springs ONLY and popped them in with the stock struts? That was mistake number 1.
Team Racing Direction
Old February 16th, 2013, 02:57 PM   #7
Dynamatt's Avatar
I bought the car with the full HFP package. So, no, that wasnt my first mistake. And the rear springs are notorious for settling in deeper than the front.
It's just the odd wheel gap that I don't like. It's 1 finger in the back and like 4 in the front
Old February 16th, 2013, 03:02 PM   #8
The vehicle level is even front and back with the HFP suspension and this is the way it should be. You are thinking that the rear settled more because the front wheel gap is in fact cut higher to accommodate for the engine's weight for larger wheel travel. So you are really looking for the raked look with the front lowered more. Take out the HFP suspension and put in aftermarket springs with Koni yellows. Aftermarket springs typically lower the front 0.25" more to "even out" the wheel gap.
Old February 17th, 2013, 11:41 PM   #9
Humble
7gv6coupe's Avatar
I got neuspeed sport Springs and the drop was even. The gap is the same all around. I would look into those if I were you.
7gv6coupe is offline   Reply With Quote Quick reply to this message
Old February 18th, 2013, 01:44 AM   #10
huffy08's Avatar
want to post a picture of your neuspeed sport drop ?
pls
huffy08 is offline   Reply With Quote Quick reply to this message
Old February 27th, 2013, 12:46 PM   #11
Humble
7gv6coupe's Avatar
Pics will be up tommorow.
Old February 27th, 2013, 03:18 PM   #12
Buy my S-Tech's I'll even be in the Valley this weekend!
Have about 25k miles on them
Will give you about a 2 finger gap in the front
Accord6Speed909 is offline   Reply With Quote Quick reply to this message
Old March 12th, 2013, 04:50 PM   #13
huffy08's Avatar
still waiting
2003 Accord EX-L V6 6MT Redondo Red Pearl
Old March 13th, 2013, 05:18 AM   #14
didnt know the hfp sagged... i just recently started noticing the rear of my car looking like it was squatting.
Old March 22nd, 2013, 01:07 PM   #15
KaotikPlaya's Avatar
I have the pro kit, and the rear wheel well sits a little lower. However, I measure to jack points, and the rear was actually higher. I also measured my stock 06 Acura TL, and it had the exact same differnce in height as my accord, with the rear being lower. And that's stock.
KaotikPlaya is offline   Reply With Quote Quick reply to this message
