will natural camber be enough - Honda Accord Forum : V6 Performance Accord Forums
Like Tree1Likes
  • 1 Post By michaellowrider
Old August 25th, 2013, 07:04 PM   #1
tcazes's Avatar
im ready to work on my stance game and want to go lower. as of now im sitting mid way down the tire but with no spacers. my wheels are +40 and im running a 225 tire on a set of 18x8s. will natural camber be enough in the front to get me all the way down to the rim on just that minimal stretch or will i need upper camber arms? i want to add spacers to get the wheels out there to almost flush. as of now im functional but im tired of being slammed but sunk in a bit..... what size spacers should i go with?
tcazes is offline   Reply With Quote Quick reply to this message
Old September 13th, 2013, 06:33 PM   #2
Banned
i know that the offset yo are running o the wheels are ok but dont know if you go to low i think that the upper arm will hit the struts holders
lokyboy69 is offline   Reply With Quote Quick reply to this message
Old September 13th, 2013, 06:37 PM   #3
JDM UC1
toinkee69's Avatar
first drop the car, then measure how big of a spacer you need.
Old September 25th, 2013, 01:33 AM   #4
So I'm new to the game. camber kits make the wheel flush with the car right?
drew_ski_ is offline   Reply With Quote Quick reply to this message
Old September 25th, 2013, 08:57 AM   #5
JDM UC1
toinkee69's Avatar
Camber kits correct the negative camber that lowering your car produces.
Old September 25th, 2013, 04:01 PM   #6
is there a preferred camber kit or do they usually come with the coilovers as a package
Old September 25th, 2013, 04:48 PM   #7
JDM UC1
toinkee69's Avatar
Camber kits are sold separately. For the front look into skunk2, Megan or ingalls. For rear ingalls, wicked, Megan or jpower.
Old September 26th, 2013, 11:19 AM   #8
alright cool thanks. sorry to temporarily hi-jack the thread but do you have an opinion on TSW wheels my friend said they are low quality but they have the style i like (and until this post I am not able to make my own thread)
Old September 26th, 2013, 11:49 AM   #9
JDM UC1
toinkee69's Avatar
TSW are ok. i say they are mid quality wheels. if they have the look that you want go for it.
Old October 24th, 2013, 12:33 PM   #10
London's Avatar
Do I need a camber kit if i were to drop my 2003 accord coupe on H&R lowering spring (Approximate 1.5 to 1.75 drop). Will the natural camber be ok with this application? Im just purchasing the lowering springs and using them with the stock struts (until I have the money to purchase aftermarket struts). I dont feel like the camber will be affected too much with just and inch and a half drop.
London is offline   Reply With Quote Quick reply to this message
Old October 24th, 2013, 05:54 PM   #11
Honda enthusiast
michaellowrider's Avatar
You'll be fine. Some ppl install camber kits to add more negative camber lol
turbo_holic likes this.
Old November 7th, 2013, 07:07 PM   #12
Vtec_Sheikhani's Avatar
I lowered my car on tein s tech springs only and i need a camber kit for the rear. I have too much camber in the rear, my tires didnt get eatin up as fast as everyone was saying they will, if anything my front got eatin up but that might just be the way i drive lol.
Vtec_Sheikhani is offline   Reply With Quote Quick reply to this message
Old November 30th, 2013, 06:27 PM   #13
tcazes's Avatar
wow i forgot about this thread. definitely needed camber arms up front but on 18's the drop was stupid having it that low because i couldn't go ANYWHERE around down. my j pipe is smashed to **** and back and it was just miserable overall so I'm back up to about half the tire. still sitting slammed but not flush with the rim anymore.
Old December 22nd, 2013, 01:33 PM   #14
Honda enthusiast
So are you getting spacers still? They would look good paired with 215/40r18 tires. You need to do some fender work to make it happen though. I think you could pull off a 20 mm spacer easy without camber arms, even wider in the rear with a good roll.
Old December 22nd, 2013, 10:10 PM   #15
tcazes's Avatar
She is rolled and pitched flat. Would need to be pulled or add some camber for sure. I'm at that magic height where no rubbing and no bottoming out so just cruising right now. I can't afford h&r spacers right now since I'm building a new motorcycle from scratch.
