7th gen accord bbk noise - Honda Accord Forum : V6 Performance Accord Forums
Like Tree2Likes
Old September 13th, 2013, 07:51 PM   #1
Banned
Smile 7th gen accord bbk noise
i upgraded my 07 accord with the bbk's the 05 rl front calipers and i have more than a year with them and they started doing noises when i push the brake pedal and when i take my foot out of the brake pedal i allready did the repair kit and they still doing the noises i will post a link that will explain the noises that my calipers are doing please i need help here case i dont know what could it be..... 05 acura rl brake noises help.mp4 - YouTube
lokyboy69 is offline   Reply With Quote Quick reply to this message
Old September 14th, 2013, 02:10 AM   #2
Banned
Can someone help me on this please need help don't know what can be and please watch the video so you can hear what the noises are and if someone of you have experience something like this Thanks people....
Old September 14th, 2013, 10:44 PM   #3
Banned
Need help please?
Old September 14th, 2013, 11:17 PM   #4
The Jester
Did you personally bleed the brake lines? New or old rotors? How were they used? What rotors are mounted to those? All bolts tight on the brackets? When was the fluid last changed? Have the calipers been rebuilt? Is there anti-creak paste on the pad side of the cylinder?
Old September 14th, 2013, 11:24 PM   #5
Banned
Yes I bleed the lines and the rotors I bought them new and they are for the 350z with brembo package I did the repair kit because 3 boots were damage and I take all apart and clean everything all pistons new pistons seals and all boots I will check the brackets tomorrow to see if they have loosen the bolts and let you know but the thing is that they make the noises only when they are hot. Did you saw the video?
Old September 14th, 2013, 11:25 PM   #6
Banned
Yes the pads have the grease on the back
Old September 15th, 2013, 01:11 AM   #7
The Jester
Have you checked the rotors for warping? How many miles have they been since a resurfacing? Do you use a brake bleed kit to keep vacuum on the brakes?
Old September 15th, 2013, 01:33 AM   #8
Banned
I think they don't have more than 5000 miles on the rotors and no I don't use the brake bleeder do I have to use that? And did you saw the video on YouTube? Cause if you saw it you can see and hear that the sounds appear when I push the brake pedal and take out my foot of the brake pedal is like something is getting stuck cause when the car is completely stopped with the brake pedal on like when you have to stop the car because the car in front of you stopped and when you take the foot out of the brake pedal and accelerate the car to keep going in that moment I feel a sound like clunk and the car starts to move but when the brakes make the clunk noise I feel like when the rotor start to spin it makes the pads push the pistons to get unstuck but I did the repair kit cleaned everything and still doing it like I said I will tomorrow take apart the calipers and check the brackets if I see that's something is not tight I will tighten the bolts and then I will bleed again to see what happen.
Old September 15th, 2013, 01:38 AM   #9
Banned
Can you give me your phone number so I can explain my self better cause I speak Spanish and the English language is my second language and don't know well how to explain my self good enough when writing so pm me your phone number please so you can help me better and thanks for help me bro.
Old September 15th, 2013, 02:21 AM   #10
The Jester
Look at brake bleeder kits, there may be air in the brake lines causing decompression and expansion of the lines. When was the last time you changed fluid? Yo no hablo espanol.
Old September 15th, 2013, 02:30 AM   #11
Banned
yes i will buy tomorow a brake bleeder from autozone and bro i know you dont speak spanish but i can talk english better than writing
Old September 15th, 2013, 02:31 AM   #12
Banned
pm me your phone number to call you thanks
Old September 15th, 2013, 03:04 AM   #13
The Jester
I'm not releasing personal info on the internet. I will help you here though.
scanlessfool likes this.
Old September 15th, 2013, 03:22 AM   #14
Banned
Ok np but you can send it via private message and no one can see the info but it's Ok I will let you know when I do the bleeding if the problem continue our if I have loosen brackets Thanks......
Old September 15th, 2013, 07:31 PM   #15
Banned
I did the bleeding and there was a little bit of air on the lines now I will run the car for a while to see if the noises starts again.
Old September 15th, 2013, 08:35 PM   #16
Banned
I did a little run on the car and the noises reduce a little but they started again tomorrow when I get to work I will notice if they are making the same noises if they keep doing it I will buy new calipers to see if mines are damage or something cause don't knowwhat else I could do to eliminate that noise.
Old September 15th, 2013, 08:50 PM   #17
rebed the pads.
Old September 15th, 2013, 09:12 PM   #18
Banned
What's the meaning of rebed?
Old September 15th, 2013, 09:20 PM   #19
yeah you probably F up the pads then, and no your not going to need a rebuild. If it is leaking then yes you will rebuild it.
Bedding-in Brakes - YouTube
Stock Brake System Bed-in
Old September 15th, 2013, 09:47 PM   #20
Banned
Did you saw the video that I posted with a link cause they don't make the noises when the car is running and I apply the brakes they do the noises when I push and let go the brake pedal see the video first and then let me know what you hear and what can be Thanks. ..
Old September 15th, 2013, 10:00 PM   #21
hmmm sounds like the calipers are flexing/ bending.
problem solved
http://forum.miata.net/vb/showthread.php?t=24413
Also just looking at your rotor. It looks like its wearing unevenly. Shinny part is wear the pad is not biting.
Old September 16th, 2013, 12:02 PM   #22
Carpe Diem
ikethegreat's Avatar
I used to get the same exact noise when I had my Wilwood BBK. I never did figure out what it was. I haven't heard it at all with my RL calipers though.
lokyboy69 likes this.
Old September 22nd, 2013, 12:13 AM   #23
Banned
Thanks bro for the update I did a complete brake system bleed and they reduce the noises a lot but still making the same noise but little ones I will do a re bleed again and let you know.
At first when I did the bbk's I dint have this noises they started to make the sounds like a year later dint know why but I will find the issue cause I give a lot of head to this issues cause when people ask I will tell them what to do.
Old September 29th, 2013, 01:30 AM   #24
Banned
hey guys whent out today for a long drive and the calipers started doing bigger noises today what can this be i did the repair kit and i bleed the brake lines and they reduce a lot but started again with the noises if anyone can help me here i will apreciate cause is getting me mad and if i have to buy another set when i get the noisy ones out of my car i will trow the with all my force to the ground please help dont want to spend another $275 $300 on a set thanks ........
Old September 29th, 2013, 04:22 PM   #25
Banned
Can someone tell me what can this be?
Old September 29th, 2013, 05:41 PM   #26
Banned
Old September 30th, 2013, 09:09 AM   #27
Carpe Diem
Since you have rebuilt the calipers, bleed the brakes, and changed pads, the only thing left it could be is the rotors. Replace your current rotors with a good quality brand and see if that doesn't fix it.
Old September 30th, 2013, 09:11 AM   #28
Banned
I will lately but the noises come out of the calipers when they are hot
Old September 30th, 2013, 09:11 AM   #29
Carpe Diem
These are the rotors I'm using and they are quite nice:
EBC Ultimax Rotor Slotted Rotor Set | Place for Brakes
Old September 30th, 2013, 09:12 AM   #30
Carpe Diem
Use promo code EBC15 to get 15% off if you use the site linked above.
