We know the TL-S anti-roll bars fit, what about struts and springs? - Honda Accord Forum : V6 Performance Accord Forums
Old February 4th, 2014, 02:56 PM   #1
Mr. Detail
Scottwax's Avatar
And what kind of height change?
Mentioned some of the mods on my car on another board, someone said he had TL-S struts and springs he took off at 26k miles and asked if I was interested in them.
I know the Accord is a lighter car (3384 lbs vs 3674 lbs) so I don't know if the springs might actually make my car sit higher due to the lighter weight. Of it if isn't enough of a difference to matter.
Neither of these charts list spring height or rate:
Acura Media Newsroom - Specifications - 2007 Acura TL - Specifications
2004 Honda Accord Sedan Specifications - Honda.com
Worth trying if they fit? Or not enough potential gain for the amount of work?
Old February 11th, 2014, 10:55 AM   #2
03 AV6 Coupe
hondav6's Avatar
I had the TL-Aspec suspension on my accord. I didn't like the way it felt. I would stay away from the TL-S suspension as well. They do fit with no issues except changing the top hats to our stock ones. I am now using Koni yellows with the eibach pro kit. it is worlds better. both the koni's and eibachs are the same shocks and springs that are for the TL-TL-S. same part numbers
Old February 11th, 2014, 04:05 PM   #3
Honda enthusiast
michaellowrider's Avatar
Get koni yellows, they have a lifetime warranty and adjustable perches, much better than oem junk. Not worth it at all to do tls oem springs struts imo.
Old February 12th, 2014, 08:28 AM   #4
The top hats are different, in the front
Don't know about rear
Old February 12th, 2014, 04:49 PM   #5
or if you wanna be cheap, the oranges are not a bad deal either
bigballer8526 is offline   Reply With Quote Quick reply to this message
Old February 22nd, 2014, 08:49 PM   #6
DreaminAccord's Avatar
7G Accord - 3G TL - 1G TSX all share the same suspension
Any of them are interchangeable with minor or no modification. Prime example, I run Tein coilovers for the CL9 (1G) Acura TSX and had to install fender washers on each side of the rear where the coilover and knuckle bolt together, as the TSX is just slightly more narrow than ours. Have been running them over a year now with no problem
Ben
(Sold 7/26/17)
(Purchased 5/18/17)
