Wheel Spacers - Honda Accord Forum : V6 Performance Accord Forums
Like Tree1Likes
  • 1 Post By michaellowrider
Old March 6th, 2014, 09:14 AM   #1
London's Avatar
Wheel Spacers
Hey guys,
I wanted to know if anyone has any experience and/or has bought wheel spacers with the stock rims. I have H&R lowering springs on the ronda right now with an 1.5 drop in the front and about an 1 in the back. The wheels look really tucked in and ive looked online and they say just to measure from the sidewall of the tire to see what you would want.
The only problem with that is I know it wont be the right size I want. I feel like it would be a lot more help getting someone who had put spacers on the measuring and then hoping for the best.
And if there is a specific brand/material that I should.
Lemme know if you guys want me to put up a picture to see what I'm working with.
London is offline   Reply With Quote Quick reply to this message
Old March 6th, 2014, 09:25 AM   #2
20mm front 25mm rear should give u a flush look. get the one with built in studs. H&R are the 2 that I know are good ibachi (spelling?)
Old March 6th, 2014, 12:08 PM   #3
Carpe Diem
ikethegreat's Avatar
+1 on the built in studs.
Ibachi Version 2 spacers or H&R DMR spacers are the ones you want.
Old March 7th, 2014, 03:53 PM   #4
Honda enthusiast
michaellowrider's Avatar
Wheel spacers are overpriced. Go on ebay and swoop some up for $75.00 a set. Aluminum material with built-in studs and a 64.1 bore is what you need. I'm running 25mm fronts and 38mm rears on 03-05 6 speed wheels (03 coupe)and it's flush. To run those specs you will need fender mods though.
toinkee69 likes this.
Old March 13th, 2014, 06:54 AM   #5
Do you know of any reputable ones off of ebay? Ones that wont break off after x amount of time...
2004av6 is offline   Reply With Quote Quick reply to this message
Old March 14th, 2014, 02:04 PM   #6
Honda enthusiast
I'm running Precision European motorwerks from ebay with no issues. Be mindful that the studs may be longer than oem and probably wont work with oem wheel locks. Open ended lugs and locks should be a consideration when choosing to run spacers. People that run into problems usually do something wrong. Check and double check that the lugs are correct for the application and not bottoming out, take measurements if you have to. Best would be to take it to someone who knows what they are doing, like me.
