Tein SS & Camber Question (Please Help) - Honda Accord Forum : V6 Performance Accord Forums
Like Tree3Likes
  • 1 Post By sgrab
  • 1 Post By aznboi128
  • 1 Post By Murders23
Old April 7th, 2014, 12:11 AM   #1
Striking-A-Chord
StrikingAccord's Avatar
Question Tein SS & Camber Question (Please Help)
I installed my Tein SS coilovers yesterday and I was wondering if the gold ring (adapter) is necessary. If so, what is its purpose?
gold rings:
&mpt=[CACHEBUSTER]">
Also, I have 17x9.5 +15 wheels on 215/45 tires. My setup rubs a bit on dips and sharp turns. I was wondering if I would need rear camber kit or just have my rear fender pulled (they are currently rolled). I want to drop the rear another 1-1/2 inches.
Thanks
2004 Accord EX V6 Coupe
Let's Go Mets!
StrikingAccord is offline   Reply With Quote Quick reply to this message
Old April 7th, 2014, 08:16 AM   #2
sgrab's Avatar
If I remember correctly the gold ring centers the spring properly. It came with the coilovers so it's probably necessary.
StrikingAccord likes this.
sgrab is offline   Reply With Quote Quick reply to this message
Old April 15th, 2014, 11:49 PM   #3
Euro accord wannabe
aznboi128's Avatar
the gold rings sits between the top of the spring and the top mount, no you dont need them, but yes they are good.
since tein coils does not compress the spring when the car is unloaded the spring might fall out of aligment its important to keep the spring in the center of the shock/ top hat thus the gold ring.
For your second question, camber would help so would pulling the fender. Depending on how much it hits that will vary on what you need to do. Double check its the fender and not just the rear bumper tab. If you haven't relocated that screw you need to.
07 accord ex-l v6 6mt coupe / HFP kit on the way / tein / yakima / TE37
07 accord ex-l v6 sedan
99 accord ex-l v6 / WW kit / tsx retro / Tein SS coils / 08 accord coupe 18"s
aznboi128 is offline   Reply With Quote Quick reply to this message
Old April 16th, 2014, 09:08 AM   #4
Murders23's Avatar
I didn't install the gold rings on my basics ( bought them used). Didn't know what they were for till now 3 years later Lol.
About comment above I never had problem with my alignment. I have lifetime alignment at Firestone and its always within spec when I get my tires rotated there. Except of course for the camber b/c I don't have a camber kit.
Murders23 is offline   Reply With Quote Quick reply to this message
Old April 16th, 2014, 12:33 PM   #5
Striking-A-Chord
Thanks guys
I'm going to get a camber kit to acquire some negative camber...hopefully I don't have to pull the rear fenders after this
