Wheel Spacer questions - Honda Accord Forum : V6 Performance Accord Forums
Old May 2nd, 2014, 05:28 PM   #1
Evan
Mass4banger's Avatar
So I got wheel spacers, and when I put them on I realized that the original bolts make contact to the back of the wheel. I could get the wheel on, but it looks like this
I know people run spacers on the back of our cars, so are my wheels the issue?
Mass4banger is offline   Reply With Quote Quick reply to this message
Old May 2nd, 2014, 10:49 PM   #2
accord325's Avatar
So your saying the bolt is too big to go through the wheels bolt holes ? Not following u, if the rims went on before they should go on now
Where is it catching ?
Old May 3rd, 2014, 06:37 AM   #3
Evan
the lugs in the hub that you put the bolts on stick out of the wheel spacer, making it so that the wheel cannot sit flush against the spacer like in the picture. I think the spacer may not be thick enough
Old May 3rd, 2014, 07:59 AM   #4
bozos_si's Avatar
I dont think your spacer is thick enough. The old lugs should not be sticking through like that.
Old May 3rd, 2014, 08:25 AM   #5
Evan
that's what i'm thinking.. Do you think 20mm spacer will work
Old May 3rd, 2014, 12:18 PM   #6
accord325's Avatar
It must be the angle of the photo but they look reassessed.
Two choices, bigger spacers or smaller lug (lugs my choice)
Old May 3rd, 2014, 12:24 PM   #7
Evan
id rather just return the spacers and get bigger ones. how big do you think they'll need to be to work?
Old May 3rd, 2014, 12:26 PM   #8
accord325's Avatar
I had 25mm hubcentric spacers and the supplied lugs worked perfect. I thought they would supply the proper size lug to have the spacer sit flush.. Seems like bad business to me
Old May 3rd, 2014, 12:35 PM   #9
Evan
its not the bolts that are keeping it from sitting flush its the lugs that that are in the cars hub stick out too far
Old May 3rd, 2014, 01:12 PM   #10
Honda enthusiast
michaellowrider's Avatar
Use a ruler, how long are the oem studs? Our oem wheels accept spacers because of the pockets.
